Home > Maintenance & Mods (L322) > How to check shocks?
Danwilderspin
Hi all how do you check shocks when you have air suspension- I may be imagining it but the front seems a little more bouncy than it did! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #567553 20th Sep 2020 6:42pm
Norm
Canada 2008 Range Rover HSE 4.4 V8 Alaska White
The easy way is to get someone to drive your car and you drive alongside in another car and just look. If you have a shock gone you'll see the wheel bouncing up and down like crazy. Failing that the old way was to put all your weight on the affected corner and then let go, try and see if that corner bonces more than the others. It should settle in one or two bonces.
Post #567636 21st Sep 2020 6:53pm
ABY
United Kingdom 2010 Range Rover Vogue TDV8 Baltic Blue
I'm getting bounce now and feeling the bumps hard ! what's it going to cost to replace the rear shocks Shocked 2010 3.6 TDV8 Vogue
Post #567976 25th Sep 2020 10:42am
Danwilderspin
Has anyone else any experience on the front as I don’t know how to test with air - do they get noisy? I have 22s so I’m not sure if the ride is down to them or the shocks or both it didn’t always seem so bouncy but could be my imagination due to lockdowns Surprised Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #569271 8th Oct 2020 11:48pm
