Home > Maintenance & Mods (L322) > Just bought a Range Rover!
Steved1806
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Hi, Ive just bought a Range Rover Westminster 4.4 TD with 85k on the clock. It has a full service history but not all from landrover dealers. There are no other receipts of work so I have no idea what has been done to it in the past.
I am looking for advice please on what I should get serviced/checked so I can help the car last.
I was thinking about a gearbox service but could anyone recommend anything else?
Many thanks
Post #566288 4th Sep 2020 4:11pm
Big Boy R44ROV
Firstly, welcome to the fold. I know you will be happy with your purchase.
I would suggest first to give it a good blast up the motorway and a few twisty bits. Listen for knocks and rattles. Clears the DPF out on a run.
Main thing on the TDV8' are turbo issues. Usually hoses and seals
What age is the car?
What tyres are on it?
And once you've done that, open your wallet and wave goodbye to whatever will go in there in the future! Laughing Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #566290 4th Sep 2020 4:22pm
Steved1806
Many thanks for the welcome and reply and the advice. its 2012 Westminster with a mixture of continentals and some aftermarket tyres.
They have a few miles left on the, but will replace later with some correct Pirellis.
I was so excited to get the car I've done 400 miles in it in the first week, including a couple of long runs. No nasty knocks or squeaks so far thankfully. I'll have a check of the turbo hoses thanks.
Post #566292 4th Sep 2020 4:28pm
mjdronfield
Turbo issues tend to be the 3.6. The main issue the 4.4 has is the oil cooler leaking in the V and oil going down the back of the engine.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #566294 4th Sep 2020 4:45pm
Steved1806
Thanks, is there any way of knowing that is happening and is it an easy fix....(doesn't sound it)
Post #566297 4th Sep 2020 5:12pm
Big Boy R44ROV
Apart from oil on the floor....and checking the level regularly it's a difficult one to see.
You could always go for the easy option like I did.
Buy a Supercharged! Tony
2014 SL63 AMG White
Gone:
00 TD5 90 County
97 3.9ES Disco
Post #566298 4th Sep 2020 5:21pm
Steved1806
That might be next. I'll see how poor I am after this one Smile
Post #566301 4th Sep 2020 5:44pm
DrRob
https://www.fullfatrr.com/forum/topic35977.html?highlight=4+4
Whip off engine cover and pollen filter box. Get on a step ladder and look in the V behind oil filter and cooler housing. Also it will drip down bellhousing onto back of engine undertray.
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #566303 4th Sep 2020 5:53pm
Steved1806
Thanks, I’ll have a look at the weekend
Post #566331 4th Sep 2020 9:09pm
jackie-o
Netherlands
Congrats on the buy!
And don’t worry about your oil cooler gaskets leaking, you will smell it.... RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #566333 4th Sep 2020 9:34pm
jackie-o
Netherlands
And, unless you can find documentation it has already been done, I would change all fluids including engine oil, diffs, transfer case and gearbox with filters.
Well worth the peace of mind imho 👍 RR Vogue 4.4 TDV8 - 11
Post #566334 4th Sep 2020 9:38pm
mjdronfield
Pics of the oil leak when I bought mine....
https://www.fullfatrr.com/forum/topic35830.html?highlight=oil
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #566337 4th Sep 2020 10:44pm
Fox889
Aaaah, another Westminster....nice!
My thoughts are the same as jackie-o.
I think most members on here could be classed as 'anal' when it comes to servicing & have their RR's spot on, I'm right up there with them.
Treat your new purchase like a 'blank canvas'. When I bought my Westie last year [12 months ago this week] I had a major service done at my local Indy, Diff oils, transfer box oil, engine oil & most important I had a Megaflush gearbox service.
There is info on this forum about the difference between a Megaflush & just a gearbox oil & filter service, worth looking at.
If you crawl under the car & look at where the rear of the engine is then look down at the exhaust, if there's oil hanging around then chances are you've got oil cooler problems. I pulled up on a petrol forecourt one day & there was a haze of burnt oil wafting up from the bonnet.......oil cooler!
These l322's are the dogs danglers, no doubt about it, but they need constant love & attention. It's taken me best part of a year to get mine how I want it, so be prepared to part with the odd penny. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #566353 5th Sep 2020 8:40am
Discotigger
Welcome to the madhouse...Forum!
Main points to check are:
Oil Cooler, as stated in posts above look for oil leaks around the V, on the engine undertray and back of engine. I had this leak and just required new O-Rings and Oil Cooler Gaskets.
Intake Plenum Hoses. Look at the four small sections of rubber hose that connect into the Intake Plenum, the original LR ones often split / perish and lead to Restricted Performance problems.
Climate seats, can get problems with the Heated Seat (mainly on driver's seat) function, caused by split / damaged ducting which leads to the peltier cell failing.
Apart from the above, the 4.4 TDV8 is an awesome Fattie, I went from a TD6 that I owned for eight years to a 4.4 TDV8 Westie late last year and the difference is unbelievable!
Finally, I would recommend you invest in a GAP IID Tool, they are absolutely invaluable and will repay themselves many times over. Thumbs Up
Post #566370 5th Sep 2020 12:10pm
Steved1806
Thanks for the advice everyone, really helpful
Post #566455 6th Sep 2020 8:18pm
