![]() | Home > Maintenance & Mods (L322) > Battery drain after the rain |
How old is the battery? Have you had it tested? |
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 ![]() ![]() ![]() |
Battery is good. It might be a year old 2 max. Also alternator is 13.75 with the engine at idle...
Neither do I. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35615 ![]() ![]() |
the most common water ingress is into the rear nearside cubby...i'd take a look in there.. ... - .- -.
It won't start again this morning. Have hooked up a battery reconditioner. I have been doing a huge amount of short journeys as we are moving house.
If you get the chance, charge the battery up and then disconnect the earth connection and leave it overnight. Then see what voltage is on the car in the morning. |
To rule out if the issue is the battery? |
I gave up bought a new battery and threw that in
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
I had something similar. Water was building up in the spare wheel well. When it got high, it caused the suspension air compressor to short out, training the battery.
JohnK Member Since: 15 Mar 2020 Location: Hampshire Posts: 61 ![]() ![]() ![]() |
Also worth a look at the headlight wipers, if they are not parking correctly they will hold the BCM on causing a drain.
Headlight wipers are all good. A new battery seems to have me sorted for the moment |
