Home > Maintenance & Mods (L322) > Battery drain after the rain
Teaspoonasaurous
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Hi again! It's been months since I've had an issue!
Anything I have an 03 l322 td6, she's well cared for new alternator and starter motor. However the recent heavy rain seems to have caused some shorting or other and I have had issues starting culminating in a complete flat in multistorey carpark today.
I'm going to invest in a jump pack, any ideas what could be triggering it?
Post #565804 28th Aug 2020 5:23pm
How old is the battery? Have you had it tested?
Post #565809 28th Aug 2020 7:22pm
Teaspoonasaurous
Battery is good. It might be a year old 2 max. Also alternator is 13.75 with the engine at idle...
I am convinced it is somehow related to water getting into something, although exactly what I don't know.
Post #565810 28th Aug 2020 7:27pm
Neither do I. Thumbs Up
Post #565815 28th Aug 2020 8:55pm
the most common water ingress is into the rear nearside cubby...i'd take a look in there.. ... - .- -.
Post #565816 28th Aug 2020 8:58pm
Teaspoonasaurous
It won't start again this morning. Have hooked up a battery reconditioner. I have been doing a huge amount of short journeys as we are moving house.
This could have contributed
Post #565821 29th Aug 2020 8:41am
If you get the chance, charge the battery up and then disconnect the earth connection and leave it overnight. Then see what voltage is on the car in the morning.
Post #565822 29th Aug 2020 8:43am
Teaspoonasaurous
To rule out if the issue is the battery?
Post #565823 29th Aug 2020 8:46am
Post #565825 29th Aug 2020 9:03am
Teaspoonasaurous
I gave up bought a new battery and threw that in
I have the old one charging and if I destroy this one I can swap back!
Post #565839 29th Aug 2020 12:16pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I had something similar. Water was building up in the spare wheel well. When it got high, it caused the suspension air compressor to short out, training the battery.
Took an bung out of the floor of the spare wheel well and it's been fine since.
Post #565852 29th Aug 2020 2:03pm
JohnK
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Also worth a look at the headlight wipers, if they are not parking correctly they will hold the BCM on causing a drain.
Especially if you have used the window washers with the headlights on in the bad weather.
Post #566430 6th Sep 2020 12:44pm
Teaspoonasaurous
Headlight wipers are all good. A new battery seems to have me sorted for the moment
Post #566435 6th Sep 2020 1:35pm
