Home > Technical (L405) > Airbag Light with B1408 Code
RR_Overlander
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Hello all
Please help if you can. My Airbag light is on (sometimes off but more times that not, it's on) with code B1408 'Driver's door window glass up circuit - circuit short to battery'. I clear the code, the light goes out but comes back immediately after the diagnostic machine is out of the menu system. I've trawled the net but can't find anything specific. Regards.
Post #565725 27th Aug 2020 8:55pm
Mr Tee
Very common, will be a break in the b pillar wiring or an issue with the connector under the passenger seat. If you search on here you will find info..
Post #565727 27th Aug 2020 8:59pm
yelnats69
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zambezi Silver
Code B1408 SRS Airbag Light
Mr Tee
I see you answered a post about Code B1408 SRS Airbag Light some time ago, I have this problem, tried following your advice but could not find any more information, lease could you in the right direction for me to research more.
Thanks Stan
Post #630665 4th May 2022 11:19pm
diesel Dave
Does your diagnostic machine do live readings? If so you can go through each airbag individual and see if any of the ohm’s readings are wildly different for one sensor, if so that’s likely to be your cause. Turned out to the the earth wire on the steering wheel airbag on mine, was a dead easy fix once located. This was also intermittent.
Post #630674 5th May 2022 7:52am
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Hi
Useful notes. Do you have any pics or can you tell me what panels to remove so I can check whether mine has the same fault please
Thanks
Regards
Mark L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone
and lots of other none LR stuff…..
Post #675250 10th Oct 2023 4:11pm
