Home > Technical (L322) > AFS problems 2006 model year 4.2SC
davidmg
2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Having AFS problems with a 2004 registered pre production 2006 model year 4.2SC
The adaptive front light warning came on with these error codes which will not clear
FLM-HeadLight
U1A38-87 (AF) Communication malfunction of left actuator - Bus signal/message failure - missing a message
( on 06-08-2020 16:02:23 )
U1A39-87 (AF) Communication malfunction of right actuator - Bus signal/message failure - missing a message
( on 06-08-2020 16:02:23 at 239956 km )
In the past there has been this fault code, which is not currently showing
FLM-HeadLight
U3000-55 (68 ) Control module - System programming failure - is not configured
( on 27-08-2019 07:49:31 at 238922 km )
So far this has been done
Replaced the battery
Swapped the headlamps & AFS ECU with known working ones
Checked the feed from the AFS ECU to headlamp plugs which is fine.
Any suggestions on what could be the cause of the problem or where to look next?
Thanks
Post #565610 26th Aug 2020 9:43pm
davidmg
Fuse box has suffered a water leak at some stage.
Replacement ordered which will hopefully cure the fault
Post #565856 29th Aug 2020 3:50pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
is it the boot seal that is leaking ?
Post #565857 29th Aug 2020 3:57pm
davidmg
It is the glove box fuse box
Post #565861 29th Aug 2020 5:27pm
MR GLOVER
wow how has the water got in there ?
Post #565918 30th Aug 2020 9:08pm
davidmg
Not sure, as it was dry when I took it out. That will be the next job to find out if & where it's coming from!
Post #565922 30th Aug 2020 10:23pm
procee
If water has got into the fusebox, also disconnect the plug on the AFS ecu in the passenger footwell and look into the pins. My AFS didn't work and after finding half the connectors in the plug were green I cleaned them. All seems good now. 2006 MY FFRR 4.2 S/C autobiography (Auckland Blue - 901)
1996 Discovery 300Tdi S (death by rusting) (Silver)
1995 Volvo 850 T-5 est (now in Valhalla) (verdigris metallic)
1987 Volvo 240 GL est (now in Valhalla - not owned but driven lots)
1990 Kawasaki ZZR600 Blue
1979 Honda CB250 NA Superdream Red
Post #566025 31st Aug 2020 11:24pm
davidmg
Secondhand fuse board fitted and all is fine now 2004 4.2 SC Japan Spec
2004 4.2 SC
2004 4.4 AJV8
Post #566198 3rd Sep 2020 4:56pm
