Home > Technical (L322) > AFS problems 2006 model year 4.2SC |
davidmg Member Since: 29 Mar 2013 Location: Nottinghamshire Posts: 63 |
Fuse box has suffered a water leak at some stage.
29th Aug 2020 2:50pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 600 |
is it the boot seal that is leaking ? |
29th Aug 2020 2:57pm |
It is the glove box fuse box
29th Aug 2020 4:27pm |
wow how has the water got in there ? |
30th Aug 2020 8:08pm |
Not sure, as it was dry when I took it out. That will be the next job to find out if & where it's coming from! |
30th Aug 2020 9:23pm |
procee Member Since: 05 Oct 2016 Location: Grampian Posts: 28 |
If water has got into the fusebox, also disconnect the plug on the AFS ecu in the passenger footwell and look into the pins. My AFS didn't work and after finding half the connectors in the plug were green I cleaned them. All seems good now. 2006 MY FFRR 4.2 S/C autobiography (Auckland Blue - 901)
31st Aug 2020 10:24pm |
Secondhand fuse board fitted and all is fine now 2004 4.2 SC Japan Spec
3rd Sep 2020 3:56pm |
