Home > Technical (L405) > Fuse box behind the glovebox
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Hello
So in a facelift car (I don't know if it was the same before), where you you squeeze the glove box to get to the fuse box?
Many Thanks SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #564490 13th Aug 2020 3:35pm
Martin2
It's in the manual (as is the detail on each fuse).....
To access the passenger compartment fuse box, open the glovebox. Press the top of the support stay at each end, and lower the glovebox into the footwell. A label on the front of the fuse access panel shows the circuits protected and the fuse locations. Remove the panel to gain access to the fuses.
https://www.ownerinfo.landrover.com/docume...c/G2203242 MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #564491 13th Aug 2020 3:41pm
luxmoggy
What is the top of the stay each side? I have tried pushing on lots of bits but nothing seems to work... SDV8 AB MY 2020
Post #564494 13th Aug 2020 3:57pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
See this link at about 39:50
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #564495 13th Aug 2020 4:10pm
luxmoggy
Thank you...
And here is a photo showing the bit to squeeze if anyone else has this issue...
 SDV8 AB MY 2020
Post #564496 13th Aug 2020 4:19pm
