Home > Technical (L405) > Fbh or Not ?
cozzy
England 2015 Range Rover Vogue SE SDV8 Corris Grey
Fbh or Not ?
Hi all ,
I have a 2017 L405 Autobiography 4.4 tdv8 Lwb which is new to me in my ownership .
My question is this........will it have a Fuel burn heater as standard ? The vehicle had no remote with it ( My Last FF L322 Vogue had it on ) when I purchased it . I would of thought a L405 AB would have this on ??
Many thanks in advance ,
Cozzy.
Post #564081 10th Aug 2020 8:08am
if you have then here will be a 'timed climate' menu in the centre dash screen.... ... - .- -.
Post #564085 10th Aug 2020 8:47am
cozzy
Thank you Stan , I will take a look later when home.
Would it be an option though ?
Cozzy.
Post #564087 10th Aug 2020 8:54am
Martin2
I've got an April 2017 price list and Timed Climate with remote is standard on the AB. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #564088 10th Aug 2020 8:58am
Chalky
Timed Climate is definitely standard on the AB. Thumbs Up You should have a dongle for it.
My car (an SE)has an app for remote climate but not using a FBH, it switches the car on to do the heating/cooling. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #564096 10th Aug 2020 10:08am
Should be standard on an AB... A remote is easily programmed so easy to rectify Thumbs Up
Post #564098 10th Aug 2020 10:30am
cozzy
Thank you for all your comments on this........the garage I bought my car from is saying the fbh is not fitted to my car (2017 4.4tdv8 AB) . I have said this is rubbish and I would like a remote that should of been with the car !!
Why do garages (some) treat their customers like utter fools........it really boils my P@#S Banging Head
Cozzy.
Post #564105 10th Aug 2020 11:16am
Not sure if it was standard.
I looked at a few when I was getting mine and the FBh was missing as a spec item. See if you can get the build sheet and check if it was optioned. I suspect it should be there. There is nothing that can't be fixed with a hammer😜😜
Post #564163 10th Aug 2020 8:08pm
Rob99
The MY17 brochure lists remote park heating as standard on AB upwards. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #564173 10th Aug 2020 10:02pm
