Home > Technical (L322) > strange noise from under the dash
pretlove
i went out to my car the other day and as i opened the door i heard a high pitch whistling noise from under the dash on the drivers side i checked all the doors was shut and turned the ignition on and off a couple of times and the noise still would not go then as i started to drive off the noise stopped....then yesterday it done it again and did not stop until id drove about 2 miles ..does anybody know what it is as its very annoying "RANGEISM WILL NOT BE TOLERATED"
Post #60571 16th Apr 2011 10:32am
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
Re: strange noise from under the dash
mouse trapped in the aircon Rolling with laughter
sorry - not!
Post #60574 16th Apr 2011 10:43am
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
I think mine did something similar about a week ago. I turned ignition off and on again and it stopped. Hasn't done it again since. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #60589 16th Apr 2011 12:09pm
could it be one of those engine hose splits you petrol boys suffer from.. ... - .- -.
Post #60590 16th Apr 2011 12:11pm
pretlove
i dont think so as it sounds electrical like a buzzer for when the lights are left on or something....if it does it again ill try to record the noise...whatever it is its behind the dash on the drivers side "RANGEISM WILL NOT BE TOLERATED"
Post #60592 16th Apr 2011 12:20pm
pretlove
im glad its not just me...i tried the ignition but no joy as i say its only happend twice "RANGEISM WILL NOT BE TOLERATED"
Post #60593 16th Apr 2011 12:23pm
pretlove
bump Crying or Very sad "RANGEISM WILL NOT BE TOLERATED"
Post #60741 17th Apr 2011 3:26pm
nobody knows............. ... - .- -.
Post #60743 17th Apr 2011 3:37pm
pretlove
Big Cry Big Cry Big Cry Big Cry it looks like ill be taking the dash apart then ill let you all know what it is if i can find it "RANGEISM WILL NOT BE TOLERATED"
Post #60747 17th Apr 2011 4:24pm
It could be the air temp sensor motor in the dash
Post #60749 17th Apr 2011 4:58pm
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
a bit like a whistle ? Like a little soccer referee is sitting in the dash? Itīs the PC fan at the bottom of the black box in the engine compartment. If you unbolt the lid of the box you will see the capsuled air fan at the bottom. Donīt spray WD40 into the little hole, better use Teflon or Siliconespray. It will help for the next month until it will be colder weather again... XJC, RRV8, Series1 86 and 107% of real pleasure
Post #60766 17th Apr 2011 6:55pm
pretlove
thanks guys ill check that out...the noise is for sure coming from under the drivers side of the dash and would it only happen now and then ...the noise you described is spot on "RANGEISM WILL NOT BE TOLERATED"
Post #60783 17th Apr 2011 9:39pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
i had similar noise, turned out to be an old parking ticket stuck deep in a top vent. 2004 black Vogue TD6
Post #60787 17th Apr 2011 10:28pm
kb5
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
I would have to agree with delsilencio //
Mine was doing this on and off for a couple of days but now seems to have stopped, I'm sure it will return so I'll have to get round to putting a new fan in .. Cost's around 120 pounds with the vat ... LRdirect part number should prob be YQO000030
It should be an easy swap out I guess.. Thumbs Up
Post #60803 18th Apr 2011 8:14am
pretlove
thanks kb5 "RANGEISM WILL NOT BE TOLERATED"
Post #60850 18th Apr 2011 2:00pm
