![]() | Home > Technical (L322) > strange noise from under the dash |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
i went out to my car the other day and as i opened the door i heard a high pitch whistling noise from under the dash on the drivers side i checked all the doors was shut and turned the ignition on and off a couple of times and the noise still would not go then as i started to drive off the noise stopped....then yesterday it done it again and did not stop until id drove about 2 miles ..does anybody know what it is as its very annoying "RANGEISM WILL NOT BE TOLERATED"
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
I think mine did something similar about a week ago. I turned ignition off and on again and it stopped. Hasn't done it again since. FFRR TD6 HSE
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35324 ![]() ![]() |
could it be one of those engine hose splits you petrol boys suffer from.. ... - .- -.
i dont think so as it sounds electrical like a buzzer for when the lights are left on or something....if it does it again ill try to record the noise...whatever it is its behind the dash on the drivers side "RANGEISM WILL NOT BE TOLERATED"
im glad its not just me...i tried the ignition but no joy as i say its only happend twice "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
bump |
nobody knows............. ... - .- -.
It could be the air temp sensor motor in the dash |
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 ![]() ![]() ![]() |
a bit like a whistle ? Like a little soccer referee is sitting in the dash? Itīs the PC fan at the bottom of the black box in the engine compartment. If you unbolt the lid of the box you will see the capsuled air fan at the bottom. Donīt spray WD40 into the little hole, better use Teflon or Siliconespray. It will help for the next month until it will be colder weather again... XJC, RRV8, Series1 86 and 107% of real pleasure |
thanks guys ill check that out...the noise is for sure coming from under the drivers side of the dash and would it only happen now and then ...the noise you described is spot on "RANGEISM WILL NOT BE TOLERATED"
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
i had similar noise, turned out to be an old parking ticket stuck deep in a top vent. 2004 black Vogue TD6 |
kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63 ![]() ![]() ![]() |
I would have to agree with delsilencio //
thanks kb5 "RANGEISM WILL NOT BE TOLERATED"
