![]() | Home > Wheels & Tyres > Tyre damage |
1880 Member Since: 18 Jul 2020 Location: London Posts: 26 ![]() ![]() |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1463 ![]() ![]() |
If it were me, I'd be sticking the spare on.
Indeed it has no full size spare sadly. Sounds like I will be replacing a brand new tyre on a brand new car...
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
That looks nasty mate, deffo get it replaced. Sidewall damage, it could deflate at any time and be b.dangerous |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Not good, Not repairable really. Off you pop to the local tyre stealer..... just don’t go putting a wangling windfarm on to save a few quids!
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
I’d wager that’s fine for the time being if you can’t see any cords or ply when you open up the cut - I’ve inadvertently driven further on much worse before. |
Yep - thanks all. Just booked in for a replacement to be fitted on Saturday bright and early before we head off on hols! £200 down the swannie - and that's before the wheel refurb (as you rightly point out). Will have to live with that for a bit I think. Tyre clearly needs fixing now. Wheel I will have to do later. And have scarcely driven the pride and joy yet! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
the inner carcass could be damaged.. I'd replace as soon as you can..
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
That’s not good. Buy some L plates to take with you on your hols, and if she is very good, perhaps you could let her have a drive in a quiet car park....... 2011 Range Rover Vogue SE 4.4 TDV8
Thanks Stan - that’s a good tip. Will ask. |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 800 ![]() ![]() |
You could then seal it with lacquer and it will protect it plus won’t be too visible. MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold |
Thanks Martin - will take a look at that. |
