Home > Technical (L322) > Trim under side Grill loose - like an air brake!?
jamesg25
United Kingdom 2012 Range Rover Autobiography TDV8 Nara Bronze
Hi Folks,
Hoping for a bit of help please, last night I was driving home on the motorway just under 70mph and started hearing a sound like an airbrake had been deployed.
obviously - twitchy bum at all at the prospect of deploying wallet, calling AA becoming the stereotype range rover on the side of the road for all and sundry to see. etc etc.
no warning lights or anything like - no decrease in performance or any other indicator of anything wrong. a mile or so on the noise dissipates dies off and doesn't return.
I did a quick walk around when i got home and there was nothing obvious apart from the driver side trim just under the side grill that also holds the mud guard on. This was quite loose on the top:
And looks like there is a trim clip missing on top right:
I had a quick look at a similar thread about removing the trim panel in this area - hoping for some advice on the best fix/way forward.
as an aside i've also plugged in the iiD tool in and there were no relevant faults - and none triggered at the time that corresponds with hearing the noise
all thoughts and comments very much appreciated.
best regards,
James.
Post #562847 27th Jul 2020 6:58pm
mjdronfield
Not sure if this helps any.... from another post...
https://www.fullfatrr.com/gallery/albums/u...dflaps.pdf
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #562850 27th Jul 2020 8:03pm
jamesg25
thanks - yes certainly good for when i take it all apart to have a look.
some reference pictures of anyone else's car - 11 or 12 plate would also be super helpful if there are any volunteers?
Cheers.
Post #562851 27th Jul 2020 8:08pm
There is an 8mm headed bolt hidden behind the inner fender splash guard... That sandwiches that panel Thumbs Up
Post #562871 28th Jul 2020 1:59am
jamesg25
super thanks - Pretty sure that's missing as i can pull the trim all the way off the car at the top - do you have a part number of picture of what it looks like?
appreciate the help.
James.
Post #562875 28th Jul 2020 7:29am
That’s the point James, when the bolt is loose you can remove the panel sir...
Where that panel joins the wing, force the wheels arch liner away and look inside with a torch and you will see the 8mm head of the fixing, with a big penny washer! That’s what you need to tighten whilst holding/pushing the lower panel in line .👍
Exactly where your thumb is in the last picture 👍
Post #562878 28th Jul 2020 8:25am
jamesg25
Contact - thank you! have located the captive nut - 8mm headed bolt and penny washer confirmed missing on both sides.
Any advice on a part number to replace?
Appreciate the help.
Post #562886 28th Jul 2020 9:21am
Classic888
VYP500120 X 2
QYF105200 X 2
DYH500190 X 2
Post #562894 28th Jul 2020 12:14pm
jamesg25
Thank you Classic888 - will get those ordered!
Post #562895 28th Jul 2020 12:17pm
