![]() | Home > Technical (L322) > Trim under side Grill loose - like an air brake!? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Not sure if this helps any.... from another post...
jamesg25 Member Since: 07 May 2020 Location: Warwickshire Posts: 24 ![]() ![]() ![]() |
thanks - yes certainly good for when i take it all apart to have a look.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
There is an 8mm headed bolt hidden behind the inner fender splash guard... That sandwiches that panel |
super thanks - Pretty sure that's missing as i can pull the trim all the way off the car at the top - do you have a part number of picture of what it looks like?
That’s the point James, when the bolt is loose you can remove the panel sir...
Contact - thank you! have located the captive nut - 8mm headed bolt and penny washer confirmed missing on both sides.
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 ![]() ![]() |
VYP500120 X 2
Thank you Classic888 - will get those ordered!
