Home > Technical (L322) > Very lairy handling..... |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Mine (2007) was like that, I sold it and went back to the Disco. Graham
17th Jul 2020 10:07pm |
MarkinNantwich Member Since: 15 Jul 2020 Location: nantwich Posts: 42 |
Bad tyre maybe? Only needs one. |
17th Jul 2020 10:38pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2515 |
Worn-out shocks jump to my mind. Replacing them does not involve a diagnostic tool and is a home mechanic type of task. The rears are easy to change as they are external to the air-springs but the fronts more involved as they're inside the air-springs. You may want to change the complete front assemblies as the air-springs don't last forever.
17th Jul 2020 11:21pm |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 |
My front adaptive shocks were leaking into the airbags. Rolled and swallowed and when I split a bag and took it off the seals the oil poured out.
18th Jul 2020 4:03pm |
WB Member Since: 26 May 2016 Location: London Posts: 303 |
If you have an IID tool it's worth calibrating the heights. Mine was way off when I bought it and recalibrating had a huge effect on the quality of the ride. |
18th Jul 2020 5:10pm |
Jorrocks Member Since: 13 Feb 2012 Location: Shropshire Posts: 55 |
Graeme and Gaz, thank you! Some stuff to check now at least. By accelerometer do you mean the height sensor thingies or part thereof?
18th Jul 2020 6:05pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7825 |
18th Jul 2020 6:56pm |
18th Jul 2020 7:00pm |
What i found on mine was that the height at each corner was out of spec (they should be from memory 493mm wheel center to arch at front and 483mm rear. Mine were all over the place - some high and some low and the result was a harsh ride. Worth a check as they can be corrected using the IID |
18th Jul 2020 7:22pm |
MJ - Thanks for those, very helpful!
19th Jul 2020 10:44am |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
@ 142k miles I would also think that there is a good chance that all your suspension rubber bushes are shot as well!
19th Jul 2020 6:46pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8309 |
My old 2002 was similar, with similar miles, I replaced the rear shocks and it was like buying a new car, you couldn't believe the difference...
19th Jul 2020 9:19pm |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 |
The other thing to check is the bushes on the rear. On my old XC90 and my brothers FFRR 5.0SC, the handling felt loose and it was the rear bushes (especially felt bad over drain covers and joins between tarmac on the road). Rob 05 L322 4.2SC
20th Jul 2020 3:02pm |
A bit of an update on this.
24th Jul 2020 12:09pm |
