Home > Technical (L322) > Very lairy handling.....
Jorrocks
United Kingdom 2018 Range Rover Autobiography SDV8 Montalcino Red
My 2010 3.6’s handling has really gone off. The car now feels like a knackered pogo stick and is occasionally quite scary if driving on uneven surfaces at moderate speeds, developing a severe diagonal wallow if you know what I mean, as opposed to a straight fore and aft sort of thing.
I have replaced the compressor as that was not working, but although I now have full raising and lowering, the handling hasn’t changed at all. I assume at 142k miles the damping in the shocks has completely gone (No oil leaks evident though). Is there anything else I should be looking at? I thought maybe the airbags, but if they hold off-road height that would rule them out wouldn’t it? The car has adaptive damping control by the way, although it patently doesn’t work at the moment!
Assuming a set of shocks is needed, is that do-able without access to an IID tool? At least to the extent I could fit the parts then drive it to a garage to get diagnostic stuff done?
Post #561839 17th Jul 2020 9:47pm
A1GSS
Mine (2007) was like that, I sold it and went back to the Disco. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #561840 17th Jul 2020 10:07pm
MarkinNantwich
United Kingdom 2011 Range Rover Vogue TDV8 Ipanema Sand
Bad tyre maybe? Only needs one.
Post #561846 17th Jul 2020 10:38pm
GraemeS
Worn-out shocks jump to my mind. Replacing them does not involve a diagnostic tool and is a home mechanic type of task. The rears are easy to change as they are external to the air-springs but the fronts more involved as they're inside the air-springs. You may want to change the complete front assemblies as the air-springs don't last forever.
Adaptive damping only softens the damping from the default maximum damping but if the shocks are worn-out then adaptive damping wont be trying to soften them.
Edit: It is possible that an accelerometer has become loose in its mountings but I would expect an adaptive dynamics plausibility fault. Remove the fuse in the rear panel for adaptive dynamics or remove the plug from the top of a front shock to disable adaptive dynamics then see if the suspension becomes very rigid (shocks are not worn out) or stays the same.
Post #561851 17th Jul 2020 11:21pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
My front adaptive shocks were leaking into the airbags. Rolled and swallowed and when I split a bag and took it off the seals the oil poured out.
Now corners well with little roll. 2011 4.4tdv8 Vogue
Baltic Blue
Post #561915 18th Jul 2020 4:03pm
WB
If you have an IID tool it's worth calibrating the heights. Mine was way off when I bought it and recalibrating had a huge effect on the quality of the ride.
Post #561937 18th Jul 2020 5:10pm
Jorrocks
Graeme and Gaz, thank you! Some stuff to check now at least. By accelerometer do you mean the height sensor thingies or part thereof?
WB, what does that actually do? The car sits level more or less at the moment, or is it more how each shock reacts in relation to the others?
Post #561957 18th Jul 2020 6:05pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #561967 18th Jul 2020 6:56pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #561968 18th Jul 2020 7:00pm
WB
What i found on mine was that the height at each corner was out of spec (they should be from memory 493mm wheel center to arch at front and 483mm rear. Mine were all over the place - some high and some low and the result was a harsh ride. Worth a check as they can be corrected using the IID
Post #561972 18th Jul 2020 7:22pm
Jorrocks
MJ - Thanks for those, very helpful!
WB - Looks like I need to bite the bullet and get an IID tool.
Post #562036 19th Jul 2020 10:44am
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
@ 142k miles I would also think that there is a good chance that all your suspension rubber bushes are shot as well!
Do an MOT type test with a pry bar and check for any loose movement, clonk, free play etc. There should not be any.
This checking is the cheapest method.
(ooh, Jensen Interceptor, any pics? )
Best Rich L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #562051 19th Jul 2020 6:46pm
My old 2002 was similar, with similar miles, I replaced the rear shocks and it was like buying a new car, you couldn't believe the difference...
Do all the calibration first, if it's still bad just try the rears, as has been said they are the easiest to do... Thumbs Up Pete
Post #562072 19th Jul 2020 9:19pm
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
The other thing to check is the bushes on the rear. On my old XC90 and my brothers FFRR 5.0SC, the handling felt loose and it was the rear bushes (especially felt bad over drain covers and joins between tarmac on the road). Rob 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #562124 20th Jul 2020 3:02pm
Jorrocks
A bit of an update on this.
The problem was primarily the rear shocks with contribution from worn control arms at the front. Replacing the shocks has resulted in a 95% improvement in handling! Replacing the control arms and the currently seized rear track arms will hopefully return the handling to it’s old self!
Thank you to all who contributed, very much appreciated!
Post #562510 24th Jul 2020 12:09pm
