Home > In Car Electronics (L322) > [MY02] 3 & 6 pin CD Changer, what are the 3 wires?
Walter Skinner
Bulgaria 2019 Range Rover Autobiography 2.0 PHEV Barolo Black
Good evening! I'm in the process of installing an Android HU to my MY02 Td6.
Right now facing a "no sound" issue, because of DSP.
Managed to score some "i-bus decoder" which is supposed to trick the system & allow DSP to startup.
To hook it up, I need 3 wires: 12v, ground, i-bus.
Now, when removed CD Changer, I've discovered two harnesses for 6 & 3 pins.
The 3 pin wires are:
- Red with green line (12v I hope)
- Brown (ground, I hope)
- White with grey line & yellow dots (which I know is i-bus).
So basically I'm looking for a confirmation that Red/green is 12v and brown is ground. Tried Rave, but my version describes completely different config.
Thanks in advance!
Post #560697 8th Jul 2020 7:03pm
Walter Skinner
Found it, C0941, looks like they are indeed 12v, ground and i-bus. Can someone confirm please?
Post #560838 9th Jul 2020 8:44pm
notanrdx
United States 2017 Range Rover TDV6 Fuji White
If you know which of the 3 is I-bus, it should be easy to confirm the other 2 as gnd and 12v with a mutimeter. Gnd should show continuity to the chassis, and the 12V should show, well 12v.
Post #560841 9th Jul 2020 8:50pm
