[MY02] 3 & 6 pin CD Changer, what are the 3 wires? | |
Good evening! I'm in the process of installing an Android HU to my MY02 Td6.
Right now facing a "no sound" issue, because of DSP.
Managed to score some "i-bus decoder" which is supposed to trick the system & allow DSP to startup.
To hook it up, I need 3 wires: 12v, ground, i-bus.
Now, when removed CD Changer, I've discovered two harnesses for 6 & 3 pins.
The 3 pin wires are:
- Red with green line (12v I hope)
- Brown (ground, I hope)
- White with grey line & yellow dots (which I know is i-bus).
So basically I'm looking for a confirmation that Red/green is 12v and brown is ground. Tried Rave, but my version describes completely different config.
Thanks in advance!
