![]() | Home > Maintenance & Mods (L322) > Steering rack |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 704 ![]() ![]() ![]() |
I don't believe its a common problem, most racks seem to last the lifetime of the car.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
A leak on a 2011 4.4TDV8 which seems to be coming from the diff?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Check its not an oil pump plug too. I had that and a leaky secondary turbo |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Thanks for the comments guys. My local indy found where the leak is coming from. Thoughts were it was from the drive shaft seal initially. The oil is leaking from the rack and dripping onto the drive shaft. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
Sounds a lot.
The rack on it's own is £2800. Rimmer Bros quote the same. I'll have to see what the warranty company says. |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2681 ![]() ![]() ![]() |
Had to replace mine when I had a 2010 tdv8, way more common than you think. I was quoted these prices too, iirc they are zf racks, which are effectively in different coloured boxes depending on gen or oem. I ended going for a refurbed, fully guaranteed unit, fitted for £1k. |
Nice to know mine ain't the only one then mate. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2640 ![]() ![]() |
Mine has joined the club. The reservoir was down 200ml 6 months ago and now down 100ml. The column seal is very wet, dripping oil onto the driveshaft boot. Any chance some-one knows the seal? |
Try these guys
Thanks DrRob.
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 ![]() |
As long as there are no proprietary seals in there it should be easy enough to get the rack re-built if you can do without the car for a week or two. I rebuilt the quick rack before I fitted it to the Impreza and it was about £70 in seals and such, plus getting all the pipework vapour blasted and re-plated. On the BMW their recommended fix for a knocking rack in warranty is to replace it at some god-awful cost. The solution out of warranty is a £30 plastic part and about half an hour's time to fit it! There's always a way to do something outside the documented procedure which is usually designed with three things in mind; a) sod the cost, the warranty co or customer are paying and b) replace the whole thing as the parts chuckers in dealerships aren't capable of rebuilding components like that and c) (and related to b), it minimises the risk of it coming back again for the same problem if some other internal part is worn for instance.
I could usually plan to do without the car for a day or 2 but I would still need someone to bring parts to me, so having the required part on hand when starting the work is highly desirable. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1553 ![]() ![]() |
What are the symptoms of a knocking rack? Lately, I’ve been occasionally hearing a clunking noise on full lock. At first I thought CV but it’s irregular so I’m not so sure. My L322 has 268,000km on it. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
