![]() | Home > Technical (L405) > L405 coolant leak FOXED |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Just in case anyone else has this issue. Problem was the a pin hole leak in the thermostat housing. In the picture you can see there is a triangular cut out in the bottom on the housing , inside of the triangle is a water channel and there was a pin hole in that channel. Leak didn't show up on a pressure test but as pics show thats where the issue was. Leak was very minimal with about a drop being left on the garage floor overnight. Im not sure i would have noticed the drop on the drive but the garage floor is painted so it showed up. Part number is LR110459.LRC for my model which is a 2015 4.4 SDV8 ![]() Cost of part was about 80 stg 2015 4.4 AB GSXR 1000 K5 R1 1998 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35619 ![]() ![]() |
that was well hidden...glad its 'foxed'.. |
It certainly was Stan |
Djardj Member Since: 30 Nov 2019 Location: Ardèche Posts: 2 ![]() ![]() |
Hi
Hi, no issues with hoses or fitting , the replacement part did have the cut out that was on the original covered so if the same pin hole leak happened the water would be contained. 2015 4.4 AB
Thank you for your answer To be clear I ´ve problem with thoose 3 connectors on the new part The diameter is approximately 1mm less than the original one, so leaky All are LR oem parts LR ask me to change the 3 hoses because the connectors are not detailed The cost is close to 500€ … ![]() ![]() |
That's strange, my replacement, also LR, was a direct replacement with no change ( That I noticed ) 2015 4.4 AB
