Home > Technical (L405) > L405 coolant leak FOXED
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I have had a coolant leak for a while , very small amount but started leaving the odd drop on the garage floor. My son took off the oil cooler today and it doesn't appear to have any visible leaks. There is dried coolant around the front and to the left handside ( looking from the front) of the engine where the oil cooler sits on. Could the base gasket leak coolant here ? All hoses seem fine with no residue. Any thoughts before he put it back together ? Thank you 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #557590 13th Jun 2020 8:36pm
dolph34
Just in case anyone else has this issue. Problem was the a pin hole leak in the thermostat housing. In the picture you can see there is a triangular cut out in the bottom on the housing , inside of the triangle is a water channel and there was a pin hole in that channel.
Leak didn't show up on a pressure test but as pics show thats where the issue was. Leak was very minimal with about a drop being left on the garage floor overnight. Im not sure i would have noticed the drop on the drive but the garage floor is painted so it showed up. Part number is LR110459.LRC for my model which is a 2015 4.4 SDV8
Cost of part was about 80 stg 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #567252 16th Sep 2020 3:11pm
that was well hidden...glad its 'foxed'.. Mr. Green Thumbs Up ... - .- -.
Post #567255 16th Sep 2020 3:18pm
dolph34
It certainly was Stan Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #567256 16th Sep 2020 3:19pm
Djardj
France
Hi
have you fixed the problem by changing the LR110459 ?
It looks like i have the same problem on my 2015 SDV8... I've changed the LR110459 but I have problems with the 3 front hoses...the male connectors looks to be change on the LR110459 compare to the initial reference... leaks...
I've ordered 3 new hoses, waiting for them (LR080118, 119 and 120)... did you have the same problem ?
thank you in advance for your feedback
regards
David
Post #618118 31st Dec 2021 9:29am
dolph34
Hi, no issues with hoses or fitting , the replacement part did have the cut out that was on the original covered so if the same pin hole leak happened the water would be contained. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #618126 31st Dec 2021 10:08am
Djardj
France
Thank you for your answer
To be clear I ´ve problem with thoose 3 connectors on the new part
The diameter is approximately 1mm less than the original one, so leaky
All are LR oem parts
LR ask me to change the 3 hoses because the connectors are not detailed
The cost is close to 500€ … Big Cry Big Cry
Post #618150 31st Dec 2021 12:44pm
dolph34
That's strange, my replacement, also LR, was a direct replacement with no change ( That I noticed ) 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #618152 31st Dec 2021 1:03pm
