![]() | Home > Technical (L322) > Courtesy light gremlin ! |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
Was messing about with the fuses trying to work out why my HDC button wasn't working and noticed the following, my dome and puddle lights work fine but i have no vanity mirror or map lights working in the front so checked bulbs which seem fine. Pulled the fuse for the interior lights and the dome and puddle lights still work !
DiscoTruck Member Since: 13 Aug 2024 Location: Sweden Posts: 5 ![]() ![]() |
Did you solve this? |
Hi, I’m afraid I never resolved this problem. I’m sure it’s an earth fault as all of sudden a couple of times a year the heated seats and map lights will work at the same time but both go off again at the same time. This suggests power does go to the lights and rear seat heaters so not a fuse issue, the HDC button has never ever worked in the car, it does work through one of the terrain response modes and the the HDC does light up on the 4x4 screen (yellow) but goes out when the ignition is switched on. |
Sounds like an earth issue or perhaps a body control module problem, others may be able to answer better if they have had similar issues relating to the door issue. My glovebox light doesn’t work either but I’ve never had issues with the doors not opening as you have. Someone once told me that the fuse that powers the rear heat seaters goes via the gear selector light panel ie whatever mode is selected ie park then the P should light red on the panel and then orange when you select drive etc, I did hear that there can be a problem with the wiring loom that is in the drivers side footwell but have never checked this out. Be interesting what JLR say if you take it in for a diagnostic check and would appreciate if you posted there conclusions. |
Thanks. Will report back what they conclude. |
