Home > Technical (L322) > Front Windscreen Wipers / Mechanism
Bigfella70
United Kingdom 2016 Range Rover Vogue SE SDV8 Santorini Black
Good evening folks,
Seeking a little advice if anyone could help please!
Driving my 2002 L322 TD6 today and upon switching the wipers on, after a couple of sweeps the passenger wiper stopped working resting in the park position. Drivers side (fortunately) carried on.
Had a quick peep under the bonnet / scuttle area and it appears that the mechanism may have come apart in the vicinity of the passenger wiper.
Is there any advice on how I can access and investigate the issue and how to repair etc?
Any pointers would be much appreciated!
Thanks.
Regards.
Dave. Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
2004 Mercedes R230 SL350
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #556413 3rd Jun 2020 8:15pm
Jayk69
any one got any info on this?
my front passenger wiper stopped today!!
hoping i can get to the assembly by removing pollen filter 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #577270 26th Dec 2020 5:23pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
This shows how to access, had a similar issue previously.
The connecting arm socket can wear & fall off. If you’re lucky you can turn it around so gravity keeps the worn end on & the good end clips back on to the linkage.
https://www.fullfatrr.com/forum/topic35804...er+linkage 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #577289 26th Dec 2020 8:54pm
Jayk69
Thanks for that very useful now my next request!!
i need the bar that joins the passenger wiper to the drivers. I have managed to pop it back on but it is no snug enough i added some grease for a bit of sticky but will not hold my breath ran the wipers for a few mins and it stayed in place.
if anyone knows the part number that would be really useful. 2012 Vogue 4.4 TDV8 - Current
Post #577356 27th Dec 2020 1:05pm
RJH
I don't think they're available separately.
You may get one off a breakers but that could be in a similar condition.
Some people have drilled a small hole through the shaft & used a washer & pin through it.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #577448 28th Dec 2020 7:24am
322BLL
Estonia
They are not sold individually. Motor together with linkage.
Years ago when searching one bar/part of the linkage I found clip from ebay, made for solving this problem. I was sceptic and ordered few. Very easy to install and has been working ever since.
Post #577450 28th Dec 2020 8:07am
Jayk69
Nice one will have a gander. failing that may add a wee bolt and washers through the middle 2012 Vogue 4.4 TDV8 - Current
Post #577645 29th Dec 2020 12:09pm
Jayk69
Found this https://www.ebay.co.uk/itm/143538883971 just waiting for seller to confirm as description says Yes but compatibility check says NO.
will update when done 2012 Vogue 4.4 TDV8 - Current
Post #577648 29th Dec 2020 12:15pm
Jayk69
So while waiting on the new poly bushes from the above link i had to re-attach, the drill bit then broke while trying to drill the centre out Censored Censored so i then thought i would try some grips and pop it went into place and can no longer pull it apart!!
lesson is if it happens to you you will not be able to push fit by hand you need some grips and a good squeeze you will feel it locate. 2012 Vogue 4.4 TDV8 - Current
Post #577788 30th Dec 2020 3:21pm
Cymro in Slovakia
Slovakia 2002 Range Rover HSE Td6 Epsom Green
Interesting point on the grips. I have this problem with it popping out at inopportune moments, like in the middle of a cloudburst just now! Had clicked it by hand a couple of times, but no joy, so had a go with grips. No luck, exactly the same result. So while awaiting the new bearing cups, tried to fill out the existing a bit. 8 layers of clingfilm and I can’t pull it apart ( not tried too hard!) So we’ll see might have to try the drilling out if it doesn’t hold.
Post #632867 25th May 2022 1:56pm
Jayk69
since i popped mine in it has held Mr. Green let hope it stays that way 2012 Vogue 4.4 TDV8 - Current
Post #633092 27th May 2022 9:27pm
