![]() | Home > Technical (L322) > Odd non starting issue |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
How long ago was the starter replaced? Sounds like battery or a premature starter failure. Might be worth cleaning up terminals and checking voltage. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Halfords if you're pushed into a corner, but any decent [or indecent] motor factor locally would be my first port of call. Great fan of Bosch, if someone offers you a 'Nappa' don't worry too much, that's a Platinum battery rebranded that's all. I've had Platinum leisure batteries before & they're perfectly good enough, it's simply 'Nappa' [USA] bought out Platinum & slowly buying every 'name' in consumable motor items. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
November 17 (13k miles ago). Previous owner bought it from Euro Car Parts (Lucas)
I don't wish to wee on anyone's strawberries, but the gold old English name of 'Lucas' died a long while ago.
Likely the starter then. Denso 1207 I’ve read being the one to get?
Thanks mate, don’t have the tool- sounds like I need to invest |
Thanks, I will get and check but it never cuts out when driving - only when starting hot or cold.
Cheers - how do I tell whether I need an AGM or not? |
It doesn’t appear to have - How would i know? |
Currently has an Avon 720CCA 95AH (353 × 175 × 190mm) fitted which is definitely the wrong one. Question is which is the right one for the car?
How do i know whether the car originally had start/stop, ie not coded out? |
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 212 ![]() ![]() ![]() |
Im sure halfords has a battery tester to check cells are ok on battery for first port of call |
4.4 tdv8 needs a type 019 AGM battery 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
So based on the above, the L322 never had a start/stop but needs an AGM battery? |
