Home > Technical (L322) > Odd non starting issue
coopss
2011 tdv8 4.4 - been at Keith Gotts for a week having ££££ spent on it.
Driving home, car driving great. Stopped at a shop after an hour drive, jumped back in, pressed the start button and all the usual lights came on but didn’t crank. Went through lock, unlock, tried with and without the brake pressed. All the dials show.
Had been doing this for about 10 minutes - battery low warning, please start engine - cheers for that !
Luckily an RAC man was next to me and connected a jump pack - nothing again. Connected to his van, 1st go, nothing, second go, starts.
It did the exact same thing a few weeks ago when cold and fired up after a few minutes without issue or jumping.
Was going to try a new battery as it’s had a starter - anything else odd it could be? Tried the searches and found mostly battery suggestions. Halfords an ok bet for an emergency?
Post #554816 21st May 2020 10:24pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
How long ago was the starter replaced? Sounds like battery or a premature starter failure. Might be worth cleaning up terminals and checking voltage. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #554818 21st May 2020 10:38pm
Fox889
Halfords if you're pushed into a corner, but any decent [or indecent] motor factor locally would be my first port of call. Great fan of Bosch, if someone offers you a 'Nappa' don't worry too much, that's a Platinum battery rebranded that's all. I've had Platinum leisure batteries before & they're perfectly good enough, it's simply 'Nappa' [USA] bought out Platinum & slowly buying every 'name' in consumable motor items. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #554823 22nd May 2020 7:18am
coopss
November 17 (13k miles ago). Previous owner bought it from Euro Car Parts (Lucas)
And thanks for the reply re the battery recommendations
Post #554825 22nd May 2020 7:33am
Fox889
I don't wish to wee on anyone's strawberries, but the gold old English name of 'Lucas' died a long while ago.
Sadly, Lucas is now just a branded name, made more than likely from China, yep, comes in a lovely green box with Lucas all over it, but unfortunately, it's 'just a name' nowadays.
Don't get me wrong, the item maybe fine, but anyone thinking "I've got a Lucas part" is under a misinterpretation of the origins.
If & when my starter goes on the blink, I'd rather have it refurbed by my local auto-electrician, then you know exactly what's been done.
Wiki
After LucasVarity was sold to TRW the Lucas brand name was licensed for its brand equity to Elta Lighting for aftermarket auto parts in the United Kingdom. The Lucas trademark is currently owned by ZF Friedrichshafen, which retained the Elta arrangement. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Post #554826 22nd May 2020 7:47am
coopss
Likely the starter then. Denso 1207 I’ve read being the one to get?
Battery does looks quite old tho
Post #554827 22nd May 2020 7:57am
coopss
Thanks mate, don’t have the tool- sounds like I need to invest
Post #554832 22nd May 2020 9:32am
coopss
Thanks, I will get and check but it never cuts out when driving - only when starting hot or cold.
Will clean the terminals. Notice the battery is definitely not the right one - only 750 cca so will replace it. Mine doesn’t stop/start so should it still be an agm? Seen various people link to a varta G14 (850 CCA) 95ah at £180. 500 on ECP!
Post #555095 24th May 2020 11:59am
coopss
Cheers - how do I tell whether I need an AGM or not?
Post #555130 24th May 2020 4:42pm
coopss
It doesn’t appear to have - How would i know?
Post #555137 24th May 2020 5:10pm
coopss
Currently has an Avon 720CCA 95AH (353 × 175 × 190mm) fitted which is definitely the wrong one. Question is which is the right one for the car?
Every website suggests a slightly different one, and each has an AGM option
Post #555161 24th May 2020 7:49pm
coopss
How do i know whether the car originally had start/stop, ie not coded out?
Post #555166 24th May 2020 8:16pm
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Im sure halfords has a battery tester to check cells are ok on battery for first port of call
Post #555167 24th May 2020 8:18pm
V8 Bob
4.4 tdv8 needs a type 019 AGM battery 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #555169 24th May 2020 8:34pm
coopss
So based on the above, the L322 never had a start/stop but needs an AGM battery?
Post #555236 25th May 2020 10:39am
