Home > Technical (L405) > Code readers and testers for the L405
diesel Dave
Hi all. I'm looking at buying a code reader and would value any advice from current users. I know the GAP IDD tool is popular on here, I have also looked at the Autel MD808 PRO, has anyone used it?
I have an airbag light on at present, (yellow), it has been intermittent but is now staying on most of the time, or comes on while driving. My question is, will the IDD tool turn off airbag warnings on the L405, looking at the manual on line it seems to have limited capacity for the L405 when compared to the L322.
The Autel says it will turn off airbag lights and most other things if you read their write-ups. But I'd rather go off experienced users advice than someones sales advert.
Post #554777 21st May 2020 6:33pm
the iidtool will clear the fault but if theres a problem then the fault will come back.....airbags are important so i'd get it sorted asap.. ... - .- -.
Post #554778 21st May 2020 6:36pm
diesel Dave
Thanks Stan, will do as agreed I'd like it as safe as can be, I think it could even be a bad connection or wiring as it come and goes but no pattern to it.
Post #554779 21st May 2020 6:38pm
not a L405 but my old td6 had an airbag light ptoblem and it turned out to be the occupancy sensor in the seat, replaced that and all was well.
it might be a thought to peruse the WM and try to identify where any 'checkable' connections might be . ... - .- -.
Post #554780 21st May 2020 6:43pm
palli
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
I also had similar problem with wiring loom damaged under passenger seat caused by seats sliding when putting back seats down. 2008 Vogue Black - gone
2012 Vogue SE White - gone
2016 Autobiography Blue - gone
2019 Autobiography Grey - gone
2020 SVAutobiography Red
Post #554800 21st May 2020 9:40pm
I had the light come on when i put the seat all the way down. Something to do with the wiring under the seat. Pushed all the plugs home as best I could and not come back since. There is nothing that can't be fixed with a hammer😜😜
Post #554983 23rd May 2020 10:44am
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
That is a good code reader and covers all cars
Post #554994 23rd May 2020 12:27pm
verydisco
GAP IDD tool all day everyday. It should come with the car from new Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #555027 23rd May 2020 4:45pm
diesel Dave
A quick update. I ended up going for the Autel code reader MD806 pro, as it reads all cars not just LR. I must say I’m very impressed with it up to now. Airbag light was a bad connection on the drivers airbag, pointed me straight to it, the scanner even has graphs of all live data so you can compare variations , IE the airbags were all circa 2.5 ohms, except drivers airbag which was 7 ohms, you could then watch it fluctuate as you turn the steering wheel proving for sure where the issue lay. I’ve also registered a new battery in the system. Will update further as I use it and get used to how it works.
PS.
My brother in law has a RR sport so will come in handy there too. Thumbs Up
Post #555033 23rd May 2020 6:15pm
Just for clarity, you do NOT need to clear airbag faults on 405's... cycle the ignition and if the fault is fixed the light will off Thumbs Up
And airbag faults on 405's usually relate to wiring under seat Thumbs Up
Post #555051 23rd May 2020 11:01pm
diesel Dave
Thanks Craig. That’s where I’ve been looking under the seats amongst other things but no luck, hence purchasing the tester, the one I had was very basic, engine codes only. I was surprised to find it on the steering wheel, the tool helped me by looking at the live values. I didn’t know they self reset on the 405 though, makes sense now why it was intermittent. Thumbs Up
Post #555055 24th May 2020 12:18am
Cagonline
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Hello Dave,
Mostly this fault airbag light fault relates to the integrity of the connector under the drivers seat.
Please see the attachments showing a diagram and a photo, showing clear identification of the connector underneath the drivers seat.
The connector in question is C33-B2 which needs to be disconnected, check the pins, clean with contact cleaner / WD40 and reconnected ensuring a tight connection.
I hope this helps,
Peter
Post #555151 24th May 2020 7:19pm
diesel Dave
Thank you Peter, pretty sure I’ve found it in the steering column/drivers airbag. But if not I will definitely check that plug out. 🔌 Thumbs Up
Thanks Dave.
Post #555174 24th May 2020 9:57pm
Cagonline
Hi Dave,
That’s good, I hope you have found the fault.
Regards,
Peter
Post #555190 24th May 2020 11:57pm
diesel Dave
Quick update, was a bad connection, earth wire on the drivers airbag module was a lose fit. Cleaned and give it a quick squeeze with the pliers, all seems ok. Thanks for the replies and suggestions Thumbs Up
Post #555559 27th May 2020 9:07pm
