Home > Technical (L405) > Code readers and testers for the L405 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35278 |
the iidtool will clear the fault but if theres a problem then the fault will come back.....airbags are important so i'd get it sorted asap.. ... - .- -.
21st May 2020 5:36pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Thanks Stan, will do as agreed I'd like it as safe as can be, I think it could even be a bad connection or wiring as it come and goes but no pattern to it. |
21st May 2020 5:38pm |
not a L405 but my old td6 had an airbag light ptoblem and it turned out to be the occupancy sensor in the seat, replaced that and all was well.
21st May 2020 5:43pm |
palli Member Since: 27 Oct 2017 Location: Suffolk Posts: 42 |
I also had similar problem with wiring loom damaged under passenger seat caused by seats sliding when putting back seats down. 2008 Vogue Black - gone
21st May 2020 8:40pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
I had the light come on when i put the seat all the way down. Something to do with the wiring under the seat. Pushed all the plugs home as best I could and not come back since. There is nothing that can't be fixed with a hammer😜😜
23rd May 2020 9:44am |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
That is a good code reader and covers all cars |
23rd May 2020 11:27am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
GAP IDD tool all day everyday. It should come with the car from new l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
23rd May 2020 3:45pm |
A quick update. I ended up going for the Autel code reader MD806 pro, as it reads all cars not just LR. I must say I’m very impressed with it up to now. Airbag light was a bad connection on the drivers airbag, pointed me straight to it, the scanner even has graphs of all live data so you can compare variations , IE the airbags were all circa 2.5 ohms, except drivers airbag which was 7 ohms, you could then watch it fluctuate as you turn the steering wheel proving for sure where the issue lay. I’ve also registered a new battery in the system. Will update further as I use it and get used to how it works.
23rd May 2020 5:15pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Just for clarity, you do NOT need to clear airbag faults on 405's... cycle the ignition and if the fault is fixed the light will off
23rd May 2020 10:01pm |
Thanks Craig. That’s where I’ve been looking under the seats amongst other things but no luck, hence purchasing the tester, the one I had was very basic, engine codes only. I was surprised to find it on the steering wheel, the tool helped me by looking at the live values. I didn’t know they self reset on the 405 though, makes sense now why it was intermittent. |
23rd May 2020 11:18pm |
Cagonline Member Since: 20 Dec 2019 Location: Nottinghamshire Posts: 15 |
Hello Dave,
24th May 2020 6:19pm |
Thank you Peter, pretty sure I’ve found it in the steering column/drivers airbag. But if not I will definitely check that plug out. 🔌
24th May 2020 8:57pm |
Hi Dave,
24th May 2020 10:57pm |
Quick update, was a bad connection, earth wire on the drivers airbag module was a lose fit. Cleaned and give it a quick squeeze with the pliers, all seems ok. Thanks for the replies and suggestions |
27th May 2020 8:07pm |
