![]() | Home > Maintenance & Mods (L322) > Auto Electrician needed |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
Anyone know of a good electrician I need to have a fault in the loom found Ta |
Dizzy Dee Member Since: 26 Dec 2017 Location: London Ish Posts: 96 ![]() ![]() ![]() |
Yes, but in Croydon, so not too far from you.
Its an interesting one the heated seats have stopped working so swapped out the switch pack still the same did put it in to na indie who found a broken wire and it worked for a few days but stopped again - I also have an airbag light which appears and disappears on the 11d tool diagnostics nothing but did have an odd suspension fault so my guess is a wire has a bad connection somewhere near the ignition switch so need a sparky to go through it all and find it |
Yes must admit have been disappointed with what I have found so far - there are a lot of taped slices nuts |
