Home > Technical (L322) > 2011 4.4TDV8 coolant expansion tank swap
ScubaVogueSE
United Kingdom 2011 Range Rover Vogue SE TDV8 Orkney Grey
Hi all
I need to swap the expansion tank in my 4.4TDV8
The bottom pipe fitting is new to me, not the common rubber pipe and clamp.
Any tips on how to remove and refit please.
Thank you
Steve Steve
Sittingbourne, Kent, UK
2011 4.4 TDV8 Vogue SE
Post #552341 1st May 2020 5:47pm
rjff
I may be wrong but have a loook at the connections on top of the fuel cooler. They have one or two push in plastic pieces
http://sc02.alicdn.com/kf/HTB1XU6MGFXXXXc....XFXXXA.jpg
which can pressed in with your fingers or else something like these:-
https://duckduckgo.com/?q=fuel+line+clip+p...iax=images
I think the bottom connectors on the expansion tank may be the same, but require anlged pliers Cheers
Richard
Gap IIDBT
Post #552344 1st May 2020 6:10pm
ScubaVogueSE
Great diagram!
Doesn't quite feel right... but it's hard to see down there. Seems bigger, about 35mm wide?
??? Steve
Post #552345 1st May 2020 6:13pm
rjff
Thanks
Have a look at the WM in the Wiki for your year and see if you can identify the connection then we can see if my info helps.
Also my bad.
On the nearside bottom connector there is a clip, 3/4 around the hose which is moved out from the connector then the hose can be eased off. There is a recent thread on dropping it Sad Cheers
Richard
Gap IIDBT
Post #552352 1st May 2020 6:39pm
ScubaVogueSE
Thanks
Found the WM and the picture shows the bottom connector must be removed, but doesn't indicate how :-/ Steve
Post #552356 1st May 2020 6:53pm
Baltic Blue
Nino will be able to help.
He has removed. his tank to clean it.
If he doesn’t respond, send him a PM ?
Post #552361 1st May 2020 7:14pm
ScubaVogueSE
Thanks!
I'm wondering if its similar to the sump plug fitment? Steve
Post #552362 1st May 2020 7:17pm
rjff
I think it looks lke this
http://www.carid.com/images/dorman/products/902-714.jpg
and you lever under the small wire clip at the bottom right. As I said there is a thread recently and the poster said to try to avoid dropping it. A piece of wire around that section may help then carefully pull the hose away from the tank connector.
good luck Cheers
Richard
Gap IIDBT
Post #552363 1st May 2020 7:21pm
nino_nino
Steve, take air filter box out and you will have plenty of space to work. fitting is like one in the picture posted by rjff. air box is held in place by tree rubber grommets, so just pull it out. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #552370 1st May 2020 8:07pm
kevinp
Re: 2011 4.4TDV8 coolant expansion tank swap
ScubaVogueSE wrote:
Hi all
Thank you
Steve
Hi Steve. Can I ask why you are changing it? I have a mysterious leak and wonder if you have the same problem. Thanks Kev.
Post #552430 2nd May 2020 2:21pm
ScubaVogueSE
Hi Nino, thanks for the advice, glad I took the airbox out.
Kev, sorry, no leak, sensor got stuck and told the car I had low coolant Steve
Post #552446 2nd May 2020 4:01pm
ScubaVogueSE
So, thanks for the advice, I managed a swap, quite painless, touch wood!
The airbox removal was very helpful, remove the rubber flexi connection pipe, cover the eng air inlet, removed the elec connection, and the little black connectors on the wire and with some wiggle it comes out, no screws or bolts.
I removed the expansion bottle by removing the lower bolt and the upper hose and twisting the bottle you can see the wire clip that needs pulling outwards of the lower connector, wiggle off.
Reverse to fit new bottle. Top up coolant. Steve
Post #552449 2nd May 2020 4:06pm
ScubaVogueSE
 Steve
Post #552451 2nd May 2020 4:08pm
kevinp
It will be nice to see the level of the coolant from the outside mate. Mine is as dirty as your old one and I have to take the cap off to see the level. Dare I ask how much the new tank cost? Cheers Kev.
Post #552496 3rd May 2020 7:01am
nino_nino
Kevinp, You can clean existing tank, I did. check this post - https://www.fullfatrr.com/forum/topic43284...k+cleaning
and pictures after it was cleand -
https://www.fullfatrr.com/forum/topic45256...nsion+tank 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #552497 3rd May 2020 7:34am
