Home > Technical (L322) > Replacing EGR pipe and EGR coolant thermostat changing TD6 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
This thread from the wiki (also see the photos, should help)
1st May 2020 2:02pm |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 125 |
There's a short piece of plain rubber vacuum hose you may need to remove to get to one of the bolts securing the thermostat. You might want to get a replacement for that in advance (any motor factor), then you can just cut the old one away and replace with new rather than struggle to pull it off the pipe each end - mine didn't want to budge.
1st May 2020 2:09pm |
MarshallW11 Member Since: 24 Jan 2019 Location: Ottawa Posts: 18 |
Have you considered deleting the whole EGR/EGR Cooler assembly? |
1st May 2020 5:33pm |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 |
I did my EGR stat a month or so ago. Didn't need to remove the fan or shroud, just the top cover that hides the stat. Maybe I was lucky but the little rubber vacuum pipe came off no problem.
4th May 2020 12:44pm |
