![]() | Home > Technical (L322) > Replacing EGR pipe and EGR coolant thermostat changing TD6 |
This thread from the wiki (also see the photos, should help)
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
There's a short piece of plain rubber vacuum hose you may need to remove to get to one of the bolts securing the thermostat. You might want to get a replacement for that in advance (any motor factor), then you can just cut the old one away and replace with new rather than struggle to pull it off the pipe each end - mine didn't want to budge.
MarshallW11 Member Since: 24 Jan 2019 Location: Ottawa Posts: 18 ![]() ![]() ![]() |
Have you considered deleting the whole EGR/EGR Cooler assembly? |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
I did my EGR stat a month or so ago. Didn't need to remove the fan or shroud, just the top cover that hides the stat. Maybe I was lucky but the little rubber vacuum pipe came off no problem.
