Home > Maintenance & Mods (L405) > Was parcel shelf changed in 18+
RRJoshA
Hi, dealer has sent me a 18+ exec parcel shelf for my 16 exec... unless I’m being very stupid it seems short so im guessing they changed with the facelift?
Post #552252 1st May 2020 9:44am
When you say short? Do you have a pic of it fitted sir?
Post #552253 1st May 2020 10:07am
RRJoshA
Post #552254 1st May 2020 10:12am
to narrow??
maybe its for a velar... ... - .- -.
Post #552260 1st May 2020 11:05am
RRJoshA
No as you can see on the first image it states L405
Post #552261 1st May 2020 11:09am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
It shows on the sticker that it's for the L405 Executive, did this have a different rear seat combination, i.e. just 2 seats in the rear with the centre console and reclining seats etc?
Post #552280 1st May 2020 12:34pm
RRJoshA
Good question. All i can see from build is its an AutoB with exec rear seating optioned
Post #552340 1st May 2020 6:42pm
Philip
The Executive rear seats changed with the MY18 facelift.
Post #552342 1st May 2020 6:49pm
725browning
United Kingdom 2017 Range Rover Vogue SE SDV8 Corris Grey
Shelf
I tried to put my 17 boot liner into the 18 plate autobiography. it would not fit Bec the exec seating makes the boot shorter by an inch or so.
Post #552354 1st May 2020 7:46pm
RRJoshA
It seems to be the width not the length. As you can see in the pictures im guessing the cover for the 18+ is about .5>1inch narrow.
They seem to not be too easy to get hold of, and silly money! Will i need a standard boot cover or does it have to be exec?
Post #552367 1st May 2020 8:40pm
725browning
I can only assume that the 18 must be an inch or so shorter in width and depth but from what I remember the 17 boot liner fitted fine for width but was too long and the boot wouldn't close. The info will definitely be available from one of the members here.
Post #552368 1st May 2020 8:48pm
It's unlikely anyone has 2 cars with different rear seats to check for you.....
Mine is non-exec and on a 2013 - its 111cm wide at the opening end and 119 wide at the seats if that helps....
Post #552405 2nd May 2020 7:43am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I do and just checked and they are different sizes Thumbs Up
Post #552416 2nd May 2020 9:44am
Rolling with laughter I forgot you had both.
So the next question is whether the pre-18 parcel shelf is the same or different for the exec rear seating vs other models. Mine has 'reclining' rear sears, so there's a flappy bit on the front edge to allow the seats to move. Not sure if that's standard or not
Post #552420 2nd May 2020 11:17am
RRJoshA
Thanks guys for taking the time to check. Think this is going to be a dealer order.
Post #552586 4th May 2020 6:50am
