![]() | Home > Maintenance & Mods (L405) > Was parcel shelf changed in 18+ |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
When you say short? Do you have a pic of it fitted sir? |
RRJoshA Member Since: 01 Mar 2020 Location: London Posts: 31 ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
to narrow??
No as you can see on the first image it states L405 |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
It shows on the sticker that it's for the L405 Executive, did this have a different rear seat combination, i.e. just 2 seats in the rear with the centre console and reclining seats etc? |
Good question. All i can see from build is its an AutoB with exec rear seating optioned |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
The Executive rear seats changed with the MY18 facelift. |
725browning Member Since: 02 Sep 2019 Location: Northampton Posts: 73 ![]() ![]() ![]() |
I tried to put my 17 boot liner into the 18 plate autobiography. it would not fit Bec the exec seating makes the boot shorter by an inch or so. |
It seems to be the width not the length. As you can see in the pictures im guessing the cover for the 18+ is about .5>1inch narrow.
I can only assume that the 18 must be an inch or so shorter in width and depth but from what I remember the 17 boot liner fitted fine for width but was too long and the boot wouldn't close. The info will definitely be available from one of the members here. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
It's unlikely anyone has 2 cars with different rear seats to check for you.....
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1467 ![]() ![]() ![]() |
I do and just checked and they are different sizes |
![]() So the next question is whether the pre-18 parcel shelf is the same or different for the exec rear seating vs other models. Mine has 'reclining' rear sears, so there's a flappy bit on the front edge to allow the seats to move. Not sure if that's standard or not |
Thanks guys for taking the time to check. Think this is going to be a dealer order. |
