![]() | Home > General > Undecided 4.4 tdv8 or 5.0 sc |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
4.4 is a different setup to the 3.6.... no real turbo issues. Main issue seems to be oil cooler leaking.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6760 ![]() ![]() ![]() |
I think a lot will depend on your likely mileage. Low miles, probably the SC. Higher than say, 12,000 miles, probably the 4.4 tdv8. Got - 2017 SDV8 Autobiography in Loire Blue
Andygriff73 Member Since: 30 Jul 2018 Location: Ellesmere Port Posts: 68 ![]() ![]() ![]() |
Thanks for the info.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 472 ![]() ![]() ![]() |
9 MPG |
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 263 ![]() ![]() ![]() |
If you weren’t towing I would say the petrol. But you would get fed up with the range, it’s bad enough when you’re not towing. Stop start range is around 250 miles, which jumps to about 350 on a run. It’s the worst part of owning a petrol. Soon forgotten when hitting the Go peddle, the 5.0 supercharged engine should be banned from a vehicle the size of a ff |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
My 18month experience with a 4.4 tdv8
Ask what proven and receipted work has been done on it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
I always check the MOT history of any vehicle I'm looking at as well. I'm looking for no gaps in the history along with no major failures (I don't like to see failures for worn tyres either, or even advisories, shows lack of attention to detail). Couple this with low owner count (dogs change hands frequently) and a rock solid service history with receipts for over and above work and you're on a good bet.
Thanks everyone for the advice looking now also at a lower mileage 3.6 tdv8 2009 on as you say low owners and good history important they are affordable luxury motors but can bite you on the arse my classic 4.2lse did just that in the first month of ownership and I am still on the forum looking to buy another rangie must be mad!! |
Turbo issues were enough to make me skip the 3.6....... rightly.....wrongly....but I didn’t want the worry, and figured it would just be my luck.....
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 212 ![]() ![]() ![]() |
SC |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Diesel engines belong in tractors, they just stink and are bad for everyone's health
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Think you're slightly wrong there dear boy! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
If the engineers had been allowed to develop the diesel engine without the interference of the tree huggers & their political puppets who inflicted all this euro I > VI nonsense on us we would have cleaner burning and very efficient diesel engines. Yes, the 5.0 ltr Superchanged is an awesome beast but otherwise nothing, but nothing pulls like a diesel. 2003 Range Rover Vogue TD6 |
