Home > General > Undecided 4.4 tdv8 or 5.0 sc
Andygriff73
Hi been away from the forum for a while the green oval as give me the call again like a bat sign.
I have had P38's before classics but never a L322 so would like some advice from you experts who own and run these lovely motors on a daily basis.
Tdv8 4.4 2012 140,000 miles 2 owners full history
5.0sc 2010 110,000 miles 2 owns full history
No rattle on the timing chain yet!! no undue noise from the supercharger on idle on the 5.0, do the 4.4's still suffer from blown turbos and egr faults like the 3.6's what mpg am i likely to see out of both?
Any help would be appreciated
Andy
Post #552180 30th Apr 2020 5:10pm
mjdronfield
4.4 is a different setup to the 3.6.... no real turbo issues. Main issue seems to be oil cooler leaking.
Torque is epic and 8 speed box is spot on.
Not been in a Supercharged so can’t comment.
Have you driven both? You need to, might help you choose.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #552182 30th Apr 2020 5:21pm
I think a lot will depend on your likely mileage. Low miles, probably the SC. Higher than say, 12,000 miles, probably the 4.4 tdv8. Got - 2017 SDV8 Autobiography in Loire Blue
Post #552185 30th Apr 2020 5:27pm
Andygriff73
Thanks for the info.
Unfortunately breaking the cardinal sin buying without driving them having been given full video's on both due to the lockdown mileage per year i would say 8-9000 a year i will be towing a caravan as well i know both will do the job and from past experience with the P38 4.6 thor 9 mpg was the norm when the lpg ran out but it sounded like thunder with the sports exhaust on it. I am tempted by the 5.0 but that timing chain!!
Post #552193 30th Apr 2020 5:54pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
9 MPG Shocked I had a 3.6 and towed a twin axle caravan all over northern Europe, average was 20 MPG, the 4.4 is suppose to be better due to 8 speed box and some trickery with sequential turbos. I've just gone 4.4 with an L405, not towed with it yet but its better than my 3.6 on fuel. Getting 35 + on a run at 70, 3.6 would struggle to break 30.
I love the sound of a petrol V8, but they just have a terrible drink problem.
Post #552197 30th Apr 2020 6:10pm
SS.Lyria
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Loire Blue
If you weren’t towing I would say the petrol. But you would get fed up with the range, it’s bad enough when you’re not towing. Stop start range is around 250 miles, which jumps to about 350 on a run. It’s the worst part of owning a petrol. Soon forgotten when hitting the Go peddle, the 5.0 supercharged engine should be banned from a vehicle the size of a ff Very Happy
But the 4.4 diesel is also a fine unit and IMHO would suit you better for towing Thumbs Up
Post #552202 30th Apr 2020 7:01pm
DrRob
My 18month experience with a 4.4 tdv8
https://www.fullfatrr.com/forum/topic44115...p;start=75
I had to get new secondary turbo. Rare job on a 4.4 but all turbos wear with time Whistle
Oil cooler leaks are the most common.
Go for it. It’s a beast Thumbs Up Perfect for blasting through Nant Francon past Llyn Ogwen Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #552205 30th Apr 2020 7:07pm
DrRob
Ask what proven and receipted work has been done on it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #552207 30th Apr 2020 7:09pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I always check the MOT history of any vehicle I'm looking at as well. I'm looking for no gaps in the history along with no major failures (I don't like to see failures for worn tyres either, or even advisories, shows lack of attention to detail). Couple this with low owner count (dogs change hands frequently) and a rock solid service history with receipts for over and above work and you're on a good bet.
I know what you mean ref fuel consumption on P38's when towing, we had a 4.0 and that managed about 11 mpg towing a loaded horse box, mind you the replacement 4.4 BMW engined petrol L322 only managed 10 mpg!! Latest addition, 4.4 TdV8 does 20 mpg towing the same horse box with the same horses, all up weight around 2.5 tonnes, so you should see better than that with a caravan. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #552251 1st May 2020 9:25am
Andygriff73
Thanks everyone for the advice looking now also at a lower mileage 3.6 tdv8 2009 on as you say low owners and good history important they are affordable luxury motors but can bite you on the arse my classic 4.2lse did just that in the first month of ownership and I am still on the forum looking to buy another rangie must be mad!!
Post #552371 1st May 2020 9:08pm
mjdronfield
Turbo issues were enough to make me skip the 3.6....... rightly.....wrongly....but I didn’t want the worry, and figured it would just be my luck.....
The price difference would have to be massive....... and even then.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #552382 1st May 2020 10:21pm
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
SC Thumbs Up
Post #552383 1st May 2020 10:24pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Diesel engines belong in tractors, they just stink and are bad for everyone's health
If you can afford to run the SC then that is the way to go for sure and leave the farm impliments to the farmers Shocked
Post #552413 2nd May 2020 9:07am
Fox889
Think you're slightly wrong there dear boy! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #552459 2nd May 2020 5:37pm
Brian Considine
If the engineers had been allowed to develop the diesel engine without the interference of the tree huggers & their political puppets who inflicted all this euro I > VI nonsense on us we would have cleaner burning and very efficient diesel engines.
Yes, the 5.0 ltr Superchanged is an awesome beast but otherwise nothing, but nothing pulls like a diesel. 2003 Range Rover Vogue TD6
Post #552472 2nd May 2020 7:01pm
