Home > Maintenance & Mods (L322) > Headlamp lens replacement |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
are new lenses available then? ... - .- -.
27th Apr 2020 1:39pm |
TonyB Member Since: 02 Oct 2017 Location: Hampshire Posts: 14 |
Powerful UK
27th Apr 2020 1:56pm |
WB Member Since: 26 May 2016 Location: London Posts: 303 |
Are you replacing them because they're cloudy or for another reason? If it's exterior cloudiness it may be possible to polish your current ones rather than replace. |
27th Apr 2020 2:25pm |
Unfortunately not, the lens is scratched. Too deep to polish out. |
27th Apr 2020 2:29pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Tony, you will struggle to remove them by heating them up as the glue is not the same as the early lamps and does NOT soften when heated! Ask me how i know
27th Apr 2020 10:32pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
So I take it you grind the old one off, after several beers so your hand is steady...?? Pete
27th Apr 2020 10:42pm |
Ive only ever removed broken ones but tried removing some in the early days of the 2009 facelift without much luck Pete! |
27th Apr 2020 10:55pm |
