![]() | Home > Maintenance & Mods (L322) > Headlamp lens replacement |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
are new lenses available then? ... - .- -.
TonyB Member Since: 02 Oct 2017 Location: Hampshire Posts: 14 ![]() ![]() ![]() |
Powerful UK
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Are you replacing them because they're cloudy or for another reason? If it's exterior cloudiness it may be possible to polish your current ones rather than replace. |
Unfortunately not, the lens is scratched. Too deep to polish out. |
Tony, you will struggle to remove them by heating them up as the glue is not the same as the early lamps and does NOT soften when heated! Ask me how i know |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
So I take it you grind the old one off, after several beers so your hand is steady...?? Pete
Ive only ever removed broken ones but tried removing some in the early days of the 2009 facelift without much luck Pete! |
