![]() | Home > Maintenance & Mods (L322) > If I were to invest in a OBD Scan Tool |
karba78 Member Since: 21 Mar 2020 Location: Plaisir Posts: 105 ![]() ![]() ![]() |
bought this
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Had an icarsoft lr2 it the IID is light years ahead. Bluetooth and app driven off phone |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
I currently have two, I started with the Hawkeye Total which does everything the IID tool can apart from modifying the CCF files, however, it can do a DPF regen. The downside is it's cable that plugs from the OBD port to the Unit itself, it's quite thick and cumbersome at times. I decided to opt for the IID tool as well after reading so much about it here. If I were to decide between the two, I would probably suggest the IID tool as it's compact and covers most of what you will ever need. The cost seems high to begin with but once you have used it a few times it's paid for itself, especially if you consider a diagnostic charge can be in excess of £75. I bought mine direct from GAP and with customs charges it came in around £450, they can be had cheaper if you look around, I should have taken advantage of the Duckworths sale of £405 when Dan was there but dithered too much. |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 ![]() ![]() ![]() |
IID great tool, aftersales service is not what I expected after reading the forum. Being a non tec, the forum reactions about aftersales where the reason to buy. But there I am seriously disapointed. |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
I recently ordered jlr ssd from ebay, so I will write up in a seperate topic what it can do and is it to complicated for diy use.
Roi354 Member Since: 06 Feb 2020 Location: Essex Posts: 32 ![]() ![]() ![]() |
