![]() | Home > Camping, Caravanning and Holidays > Gas Bottle Weights - Full and Empty |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1462 ![]() ![]() |
Hi all
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Rob,
Thanks Mike
Sorry Rob , I have only got the 7 kg cylinders, but I like you never have been able to tell how much gas was left in each.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
i dont think the gas weighs anything, being lighter than air....
My empty one is definitely empty, and the full one has still got the plastic sealing cap on.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
Hi, What you also have to consider is the ambient temperature? the LPG boils at an ambient temp that's why you hear a hiss when the gas is used from the cylinder, So if the temperature is low it would appear that you have run out of gas? say a cold night then at around midday when the sun is out you still get some gas out of the cylinder when you had thought it was empty.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
Hmmm - so 7kg of gas weights 6kg - sounds like a con to me - I'd take it back & complain |
The weight of the cylinder is stamped on the cylinder without gas. |
I'm resisting the temptation to go outside to check |
I should add that my luggage scales cost me about £5- £6.
I think they will be collecting a lot of dust in the current climate? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
You will struggle to fit the bigger bottles in the gas locker.👍🏻 There is nothing that can't be fixed with a hammer😜😜
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
If you go onto the red gas bottles, they have a nifty gauge fitted at the top.
Alfa Romeo Giulietta Just one Montesa now, 349 White Wonder Austin A40 Farina MK2 1975 Morris Marina 1.8TC 1973 Honda CB250 K4 |
