![]() | Home > Wheels & Tyres > tires |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 ![]() ![]() |
They are effectively 33 inch od... Your going to have an extra say14mm of tire which will rub inner guard up front when turning as the smaller size you mention which I run can also at times. Be interesting to see how you go, how much rubbing your going to accept. Make sure your bushes in lower control arms are in good shape to avoid excessive movement giving you less clearance
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 776 ![]() ![]() ![]() |
thanks for your reply
