Home > Wheels & Tyres > tires
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
tires
hi
got the chance of buying some ATTURO tires 275-60-20
presently running 275-45-20
do you think they will fit ok, or can you see any problems running these
thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #550375 15th Apr 2020 1:56am
Bluegreygreen Rangie 2
Australia
They are effectively 33 inch od... Your going to have an extra say14mm of tire which will rub inner guard up front when turning as the smaller size you mention which I run can also at times. Be interesting to see how you go, how much rubbing your going to accept. Make sure your bushes in lower control arms are in good shape to avoid excessive movement giving you less clearance
Dave 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #550377 15th Apr 2020 5:24am
knares
thanks for your reply
i ended up giving them a miss RR 2005 4.4 petrol
Post #551333 22nd Apr 2020 4:00am
