Home > General (L405) > Beware dpf blockages in current times |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1098 |
Can someone post up the conditions required for standard self clean. letters not necessarily in the right order |
30th Mar 2020 10:22am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7964 |
No perfect definition as it requires certain temperatures to be achieved - 30mins + on a motorway for example
30th Mar 2020 10:39am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
Greg, GGDR, posted this last September at which time the iiD tool couldn't force a regen. Don't think that has changed. https://www.fullfatrr.com/forum/topic52931...ap+iid+dpf He may have some more info. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
30th Mar 2020 10:58am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
I've always done short journeys - and yes had DPF issues.
30th Mar 2020 11:26am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35435 |
i dont do many miles and most of my journeys are a 8 mile round trip to the local supermarket and i've had only 2 yellow dpf warnings in the 3 years of 4.4 ownership...
30th Mar 2020 11:31am |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
i do (sorry, used to ) the school run, about 2 miles most days(no real traffic jams), odd shopping errands and to the stables close by. If in a period of between working then I rarely do any long runs, I will get the amber warning about once a month. As Stan says a 20 minute motorway run and I’m good to go. |
30th Mar 2020 11:54am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7834 |
So.....I’m classed as a key worker......and might need my car to get to work....if I don’t give it a run, I will have DPF issues and then can’t use car to get to work....
30th Mar 2020 3:37pm |
If your car has just been stood then it doesnt affect the dpf. It will be fine. Dpfs only really clog when engines never get proper chance to warm up so are initially running a rich fuel mixture and EGR’s are closed (as they are cold) thus there is a higher percentage of particulates. It can also happen a lot if sat in traffic engine idling a lot due to the EGR being closed on idle. When engines are able to run at higher speed (motorways for example) every so many miles (actually it’s measures on pressure differential) the engine ecu will trigger a dpf regen. This alters the fuelling to run at higher temps so burning off ash that accumulates in the dpf. This is done automatically - you won’t even notice it. |
30th Mar 2020 5:11pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
If you get an amber warning, i can drive to the motorway 3 or 4 mins away and if i join the motorway Northbound, its 1.5 mile to the next jn and its normally re-gen'd by the time i get to the junction! All done at 50-60mph... |
30th Mar 2020 6:07pm |
