![]() | Home > Maintenance & Mods (L322) > 2004 TD6 gear selector problem |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1002 ![]() ![]() |
Welcome to the forum.
Graham Nic Member Since: 11 Mar 2020 Location: Lerwick, Shetland Posts: 16 ![]() ![]() |
Hi, I spray oil where the selector shaft goes into the casing? looking at your pictures could it be the seal on the casing that's swelled? |
I’ve never heard of that seal causing an issue before, but there’s no harm in trying it. The Land Rover part number is TLM 000020.
Hi, thanks for the info. Yeah as I said before I thought it was the cable? I'm in the middle of changing out the engine (done 187,000 and dropped an exhaust valve in No 6 and not worth fixing), so dropping the gearbox as well. So will get a chance to have a better look at it?
update on my selector problem, I think I have found the problem? while removing the box I found that the swivel on the selector lever was frozen. The selector shaft moves freely as does the selector cable. So fingers crossed it was the swivel that was causing the problem?
The oil pump rotor (& corresponding slide) are a selective fit in the GM 5L40-E. There are 5 classifications:
