Home > Technical (L322) > Locked out! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7937 |
11th Mar 2020 8:56pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3771 |
11th Mar 2020 9:10pm |
NotDave Member Since: 28 Feb 2016 Location: North Wiltshire Posts: 26 |
Alistair, I have the keyhole but the key doesn't do anything - I thought the lock was mechanical rather than needing electrical power but for some reason it just won't unlock.
11th Mar 2020 9:27pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Then get under the car, pos lead to red cable on the starter motor, neg cable to good earth, other ends to another battery?
11th Mar 2020 11:19pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 223 |
And when you do get in get your self a bmw e46 door lock repair kit to fix the key barrel not operating the lock, easy to do and cheap (been there, done that but found out about it before in need of useing key in door). |
11th Mar 2020 11:56pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1381 |
When locked out of my 2012 WM due to flat battery I couldn't get the key to open the passenger door either, but the LR Assist technician managed it, presumably there is a knack to it, so getting someone who is used to them to try might be worth doing before anything as drastic as breaking a window. He did say my experience was not atypical. Only Range Rovers since 1988 |
12th Mar 2020 11:06am |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
What annoys me is why is it the passenger door?? I know its because most markets the passenger door is the drivers door, I get that for most brands. But LR is British it should be the drivers door. |
12th Mar 2020 11:58am |
neil3728 Member Since: 24 Feb 2020 Location: Howden Posts: 51 |
Every car I have had no matter the make or model, it has always been the passenger door, no real idea why. 2011 Vogue 4.4 TDV8
12th Mar 2020 1:12pm |
I'm in!
13th Mar 2020 9:07pm |
13th Mar 2020 9:52pm |
