Home > Technical (L322) > Locked out!
NotDave
United Kingdom 2015 Range Rover Vogue SE SDV8 Scotia Grey
Locked out!
Hi all,
Thought I'd charge the Fatty up today and get it started so I could maybe think about moving it on or getting it fixed. Unfortunately I must have left it a bit too long as the battery has gone too flat for the remote locking to work and I can't unlock the drivers door with the key either! Is there a secret to unlocking with the key? Call me old fashioned but I assumed you just turned it one way or the other and it would lock or unlock just like car doors used to do when life was simpler. Rolling Eyes
So the question is, how the heck do I get into the car? I don't really want to put a lump hammer through a window or smash the front grill but at the moment I'm running out of ideas so any thoughts would be appreciated....
Thanks in advance. Ed.
Post #546852 11th Mar 2020 9:49pm
https://www.fullfatrr.com/forum/topic38460.html
Post #546853 11th Mar 2020 9:56pm
Baltic Blue
Adaptor available from site shop.
Post #546856 11th Mar 2020 10:10pm
NotDave
Alistair, I have the keyhole but the key doesn't do anything - I thought the lock was mechanical rather than needing electrical power but for some reason it just won't unlock.
Baltic Blue, that's a great idea but I've only got ye olde fashioned 7 pin black capped socket unfortunately!
Thanks for the ideas though.
Ed.
Post #546861 11th Mar 2020 10:27pm
Then get under the car, pos lead to red cable on the starter motor, neg cable to good earth, other ends to another battery?
or
Remove nearside (RHD) inner wheelarch, use long tools to pop the bonnet catches .
Post #546869 12th Mar 2020 12:19am
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Ed.
And when you do get in get your self a bmw e46 door lock repair kit to fix the key barrel not operating the lock, easy to do and cheap (been there, done that but found out about it before in need of useing key in door).
Post #546872 12th Mar 2020 12:56am
CS
When locked out of my 2012 WM due to flat battery I couldn't get the key to open the passenger door either, but the LR Assist technician managed it, presumably there is a knack to it, so getting someone who is used to them to try might be worth doing before anything as drastic as breaking a window. He did say my experience was not atypical. Only Range Rovers since 1988
Post #546899 12th Mar 2020 12:06pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
What annoys me is why is it the passenger door?? I know its because most markets the passenger door is the drivers door, I get that for most brands. But LR is British it should be the drivers door.
Post #546907 12th Mar 2020 12:58pm
neil3728
United Kingdom 2013 Range Rover Vogue SDV8 Baltic Blue
Every car I have had no matter the make or model, it has always been the passenger door, no real idea why. 2013 Vogue 4.4 TDV8
2014 Defender 110. now sold
2018 Range Rover Sport.
Post #546914 12th Mar 2020 2:12pm
NotDave
I'm in! Thumbs Up
Thanks for all the suggestions folks. Had a go at prising the scuttle panel up yesterday but could only reach the negative terminal and then ran out of time. Made my mind up that I was going to start the car today no matter what. Found a few small strips of wood, maybe 1" x 1.5", and managed to wedge them in behind the scuttle adding a few more until I could see and touch the positive terminal. Luckily I have quite small hands and eventually had enough room to attach the charger to the positive. Found a good earth underneath the car and all was good. The battery must have been deader than a dead thing because it took at least 20 minutes to get enough power in the system to unlock the central locking!
Left the car charging for a few hours and then it started reasonably well, took it for a quick spin up the road just to blow the cobwebs out and now it's having an overnight trickle charge.
Still can't believe my luck managing to do this on my own without having to pay anyone to help me, just need to decide what to do with the car now....
Ed.
Post #547041 13th Mar 2020 10:07pm
Thumbs Up Thumbs Up Thumbs Up .
Post #547049 13th Mar 2020 10:52pm
