Home > Maintenance & Mods (L322) > Howling noise from engine bay
spanielzrus
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
I've had a look around on the forum for an answer to this but cant find anything that exactly matches.
Vogue TD6 2006 BMW
When starting from cold I regularly get a low-mid pitch 'howling/honking' noise that I think I've tracked down to the area of or near the battery compartment/pollen filter. It definitely at the top and rear of the engine bay and more on the nearside than offside.
I've tried the rubber hose 'stethoscope' approach to try and isolate the sourse without any real success and the noise always disappears after a couple of minutes of driving.
It driving me mad Big Cry
Any helpful suggestions gratefully received.
Post #546542 9th Mar 2020 12:54pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
have you checked for splits in turbo hoses
Post #546543 9th Mar 2020 12:56pm
spanielzrus
Yes all turbo hoses appear to be fine.. No whooshing noises. Sure noise is coming from up high in the rear of the engine bay/heater intake/battery area.
Post #546544 9th Mar 2020 12:58pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
FBH would be my guess, if one is fitted. L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #546548 9th Mar 2020 1:15pm
spanielzrus
Unless I'm mistaken (quite possible BTW) the FBH is in the wheel arches? Confused
Im not discounting this but why would it give the noise so high up in the engine bay area?
My little grey cells are jangling about a post (can't remember where) that i read about some sort of 'flap' in the fresh air induction unit but i cant find it again any where.
Again thanks for the replies. I love a good mystery Rolling Eyes
Post #546558 9th Mar 2020 2:17pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
FBH itself is in the engine bay, next to the N/S suspension turret, but yes the exhaust for it is in the wheel arch. 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #546678 10th Mar 2020 12:51pm
spanielzrus
I'll take a look at the FBH and see if I can get any further. Also I think I found the other post I was referring to. It was to do with the "HVAC recirculation valve". Anyones thoughts on that one? Is it easy to get to/check/replace? Many thanks.
Post #546680 10th Mar 2020 12:58pm
spanielzrus
Found the following online which sounds exactly like the problem. Will do some investigation with the FBH when the weather improves. Thanks again for the replies.
Post #546786 11th Mar 2020 12:31pm
