![]() | Home > Maintenance & Mods (L322) > Howling noise from engine bay |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
have you checked for splits in turbo hoses |
spanielzrus Member Since: 20 Aug 2019 Location: Dunfermline Posts: 8 ![]() ![]() ![]() |
Yes all turbo hoses appear to be fine.. No whooshing noises. Sure noise is coming from up high in the rear of the engine bay/heater intake/battery area. |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
FBH would be my guess, if one is fitted. L322 3.6 TDV8 Vogue. 07MY
Unless I'm mistaken (quite possible BTW) the FBH is in the wheel arches? |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
FBH itself is in the engine bay, next to the N/S suspension turret, but yes the exhaust for it is in the wheel arch. 2004 Vogue TD6 - Remapped |
I'll take a look at the FBH and see if I can get any further. Also I think I found the other post I was referring to. It was to do with the "HVAC recirculation valve". Anyones thoughts on that one? Is it easy to get to/check/replace? Many thanks. |
Found the following online which sounds exactly like the problem. Will do some investigation with the FBH when the weather improves. Thanks again for the replies.
