Home > Technical (L405) > L405 4.4 Sump
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
L405 4.4 Sump
Does anyone have detailed pictures of a 4.4 SDV8 engine sump, or ideally has one off a car locally that I can have a look at and measure, please?
It doesn't matter if it is damaged or unserviceable in any way. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #545539 29th Feb 2020 12:06pm
Question Question Question
Im intrigued as to why sir?
Post #545556 29th Feb 2020 1:32pm
Baltic Blue
Try a search for a thread by Salter 21? , or a PM to him.
He rebuilt a L322 with a new L405 4.4 engine, but had to swap the sump back to the L322 version.
Post #545577 29th Feb 2020 3:16pm
Zebedee
Thanks Mike - will try him.
The reason for the sump enquiry is:
You may have seen the thread about the £20k L405. One of the issues that needs to be addressed is the failed oil level sensor, which requires a 10-hour job to replace - just to find out how much oil is in the sump.
What I've found so far is that the sensor was originally designed to fit externally from bottom of the sump. It has an oil control seal and failure of the sensor would require an oil drain, 3 bolts removed and the sensor removed and replaced - all taking about 15 minutes. I think the sensor on the L322 4.4 is mounted externally, as is most [all?] applications of this type of sensor.
Land Rover, in its infinite wisdom, decided for the L405 4.4 that the sensor needed to be mounted inside the sump - possibly because of the amount of oil required in the 4.4 meant the standard sensor was not long enough. Which is fine until it fails. To replace it now requires both front drive shafts to come off, the diff to come off, then drop the front subframe to give access to the sump bolts - hence the 10 hour job. Maltings 4x4 have said that they are doing more and more of these sensor replacements.
What I'm considering is creating a canister connected to the sump oil that can be mounted to the side of the engine, and the oil level sensor can be mounted to the bottom of this canister (so the sensor is easy to change). I need to know roughly the height that the sensor should sit in the sump in order to know roughly where the new cannister needs to sit. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #545680 1st Mar 2020 5:04pm
Baltic Blue
https://www.fullfatrr.com/forum/topic47799.html
Found it.
Mike
Post #545683 1st Mar 2020 5:27pm
