Home > Maintenance & Mods (L405) > P0546 error code - EGT sensor 1 bank 1 - where is it?
bacr
2015 Range Rover Autobiography SDV8 Loire Blue
I am new to the world of Range Rover and a couple of months into ownership have had the engine light come on with the errors p0546 and p2080 which appear to relate to the EGT sensor 1 bank 1. If someone could help steer me in the right direction on which sensor to replace that would be very much appreciated. I have had a good search of the forum but not come across this error code.
The read outs also appear to show EGT and EGR sensor bank 1 sensor 2 having no readings, is that right?
https://ibb.co/84Vbry7
https://ibb.co/nbS3nTp
https://ibb.co/K6jhVGj
Post #544756 22nd Feb 2020 9:19am
welcome to the forum...can you fill in your car profile so we can answer your question accurately.. ... - .- -.
Post #544758 22nd Feb 2020 9:43am
bacr
Sorry, just updated. It is a 2015 autobiography 4.4 SDV8.
Post #544761 22nd Feb 2020 9:57am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I would put a dedicated LR code reader on it and see what it says. I'm just not sure you can trust the results from a generic reader. Having said that, I'm not sure what options you have with an L405. iCarsoft is cheap but I don't know if it supports the L405. Or IID?
Another option is to post your rough location and see if any friendly member would read the codes for you. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #544766 22nd Feb 2020 10:53am
bacr
I’m in Taunton in the south west if that’s close to anyone? Very Happy
Post #544774 22nd Feb 2020 12:03pm
MikeO
You could try starting a new thread with a title along the lines of "Help Requested - Read Codes nr Taunton" or similar.
People tend to read the titles but not always the detail of the messages. I'd offer to help but I'm a bit far from Somerset. 2016 Skoda Octavia VRS Estate
Post #545031 24th Feb 2020 4:31pm
Ritchey
To the original poster, I am experiencing these identical 2 x codes on my 2018 RRS 4.4 SDV8.
Did you get to the bottom of the cause of the fault?
Thank you
Post #710331 27th Jan 2025 2:22pm
darren3005
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
I have a G3 IID tool quite handy TBH, but it thought it was locked to my car and only my car. I'm north of Taunton, outskirts of Bridgwater in fact. so if its possible I can use my IID tool to read your car. You've bought WHAT!!
Post #710332 27th Jan 2025 2:42pm
bacr
It was on my last RR but from memory it was a an EGT sensor that needed a special tool to be able to reach. I went to a specialist who said if he could get it out it was c£300 to replace but if the sensor broke it would be about half a day to a days labour as he would need to take the engine out. I went to JLR dealer and they said it was c£400 fixed as they had to go by the hours in the book no matter what happened. So I went with JLR.
Had a member on here just recently who said he had the same thing, went to a specialist and they broke the sensor and he now faces a up to a days labour to fix so I would say worth using JLR dealer for this.
Hope that helps
Post #710377 27th Jan 2025 9:51pm
Ritchey
That’s a huge help, thank you 🙌
Post #710429 28th Jan 2025 1:54pm
