![]() | Home > In Car Electronics (L322) > No iPod connector.. am I out of luck for Bovee? |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
in our 4.2 07 i have only found the aux input.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2681 ![]() ![]() ![]() |
Not sure about the earlier ones but my 2010 had the connector in the centre cubby |
Garnerj Member Since: 07 Aug 2018 Location: Milton keynes Posts: 58 ![]() ![]() ![]() |
My 2010 and 2011 have the iPod in port in the cubby box. It then has. A cable which goes down to a module under the passenger seat which is linked into the fibre optic MOST network. I imagine it can be retro fitted if it was available in that year but prob needs to be enabled in the ccf. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
For your year of car this LR unit provides an ipod connection. https://www.fullfatrr.com/forum/topic40270.html?highlight=audio It was an option and I did retrofit one which works pretty well with an old iPod 4. It is quite a strip out to fit it. There are still some available for sale if you search about. Duckworths may still have some. Located in the glove box. Tucked up in the back. There may be probably easier ways to achieve what you want. PS. The NAvtool would give you more although still a few dollars. https://www.fullfatrr.com/forum/topic53128.html?highlight=navtool John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50 ![]() ![]() ![]() |
ill add i have the same year FFRR with Ipod and it does not work with a BOVEE or a generic ipod to bluetooth adaptor. only the newer L322's with the newer audio system will work with a BOVEE which is a shame. |
JohnGalt11 Member Since: 31 Mar 2020 Location: Iowa Posts: 27 ![]() ![]() ![]() |
I ran a 90deg bend 3.5mm Aux cable within the center console and and up into the ashtray/cubbie. There it connects to a $15.00 MPOW bluetooth adapter that is small enough that I used velcro to attach it to the inside of the ashtray lid (the ashtray in mine is missing, and I don't smoke anyway). The 12V plug there means that I can use a 10cm power cord to charge the battery on the BT adapter when necessary without a long cord strewn all over the place. This way, I can still close the lid and the setup is invisible, (although I can't close the lid while it's charging) or, I can open the lid and access the play/pause and track +/- buttons so I can change the slong without accessing the phone. Granted, nothing shows up on the infotainment screen, and the track buttons on the steering wheel don't work with this setup. This setup offers a few benefits from just plugging the Aux cable into the phone. First, it eliminates the need to access the music app on the phone to change songs etc. Second, it eliminates the wear on the 3.5 mm jack on my phone, or permits the use of the FFRR aux port with devices that do not have a 3.5mm jack. Third, placing it inside that cubby looks nice and more importantly it prevents kids or pets or people from kicking the BT adapter or the plug and breaking it or the aux port since it is right at foot height for rear seat passengers. It also puts it in a location that is easily reachable while driving for changing songs. I still use the vehicle BT system for phone calls, but if you wanted to use the adapter for voice calls, then putting it closer to you (instead of in the rear passenger area) will provide better microphone performance. Forth, the 90 deg cable in the Aux port permits the cover over the Aux port to still be closed even whil it is plugged in. Keeping it safer and looking nicer. The only part of the aux cable that is visible is the 4 cm or so between the Aux port and where it enters the center console vent immdiately below it. I can put links to the materials I used if or take some pictures if anyone is interested. 2009 L322 SC |
